Page 1 of 3 1 2 3
360 losing oil pressure when reved up. #327555
05/24/09 08:37 PM
05/24/09 08:37 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
its not low on oil either. seems to drop oil pressure when i wind it up.
its an old motor. a 1971 thats never been torn down but only has 75,000 original miles on it.was running good .
Re: 360 losing oil pressure when reved up. [Re: dirt] #327556
05/24/09 08:59 PM
05/24/09 08:59 PM
Cleveland Ohio
sportfury70 Offline
sportfury70  Offline
Cleveland Ohio
sludged up oil pickup?
Re: 360 losing oil pressure when reved up. [Re: dirt] #327557
05/24/09 09:03 PM
05/24/09 09:03 PM
northeast texas
strokin73cuda Offline
northeast texas
had a couple stock engines when mains were bad would drop in oil pressure while under acceleration and gain it back when deccel. in same gear also if its an elec. gauge try adding it with mechanical and see what happens.
496 stroker,Indy srs , new best 6.87 @ 98 1.46 60'
Re: 360 losing oil pressure when reved up. [Re: strokin73cuda] #327558
05/24/09 09:20 PM
05/24/09 09:20 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
it allready has a mechanical gauge. was originally a 2 barrel motor . i swapped on a 4 barrel about 1000 miles ago and have been running it a little harder than it was before. never past 5,000 rpm's though.
Re: 360 losing oil pressure when reved up. [Re: dirt] #327559
05/24/09 09:24 PM
05/24/09 09:24 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
been said here before,, plugged up oil pick up screen.
Re: 360 losing oil pressure when reved up. [Re: dartman366] #327560
05/24/09 09:43 PM
05/24/09 09:43 PM
northeast texas
northeast texas
try bringing the car up to highway speed in drive take a note of the pressure then accelerate but not enough to hit passing gear if the pressure falls then let off the pedal the pressure may rise, if not then its not the mains and hopefully not but its easy to check and i always chack the easiest thing first at least when my heads not up my ### maybe even try changing oil and filter.
Re: 360 losing oil pressure when reved up. [Re: dartman366] #327561
05/24/09 09:58 PM
05/24/09 09:58 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Valve stem seals packed in the pickup.
Re: 360 losing oil pressure when reved up. [Re: Hot 340] #327562
06/08/09 12:39 PM
06/08/09 12:39 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
dumped in some lucus oil treatment and it fixed it. not sure what that means though
Re: 360 losing oil pressure when reved up. [Re: dirt] #327563
06/08/09 03:39 PM
06/08/09 03:39 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
It means that you may have loose mains and that you thickened the oil.
Re: 360 losing oil pressure when reved up. [Re: MoparforLife] #327564
06/08/09 04:31 PM
06/08/09 04:31 PM
, PA
sleepyhead416 Offline
, PA
Take for oil pickup off you'll find all your valve seals stuck in screen.
Re: 360 losing oil pressure when reved up. [Re: sleepyhead416] #327565
06/08/09 06:31 PM
06/08/09 06:31 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
it has been blowing a big puff of smoke when i fire it up.
Re: 360 losing oil pressure when reved up. [Re: dirt] #327566
06/08/09 07:20 PM
06/08/09 07:20 PM
Upper Midwest
Upper Midwest
Points to valve seals and guide wear. but won't effect your oil pressure.
Re: 360 losing oil pressure when reved up. [Re: MoparforLife] #327567
06/08/09 10:32 PM
06/08/09 10:32 PM
God's Country Maryland
GODSCOUNTRY340 Offline
If it smokes on start up the valves seals are bad. They're so bad they've hardened, broken apart, fallen into your oil pan and are plugging the pick-up tube screen.
Re: 360 losing oil pressure when reved up. [Re: GODSCOUNTRY340] #327568
03/26/14 02:04 PM
03/26/14 02:04 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
I finally pulled the oil pan off and removed the oil pickup tube. it was not clogged.
the motor is on an engine stand now.
the motor has never been apart and only has a little over 70,000 miles on it but it is a 1972 so its old.
how can I tell if the bearings are the issue?
I would like to pull the heads and have them redone and continue to use the motor in my pickup. I was hoping to get by with just installing new rings and bearings since it is low mileage and still ran good.
Re: 360 losing oil pressure when reved up. [Re: dirt] #327569
03/26/14 02:47 PM
03/26/14 02:47 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Wow, an OP reviving a 5 year old thread
Carefully remove the main caps, take lots of pictures and post them up here. Don't mix anything up or drop it yet.
I'm assuming you don't have access to a bore mic and calipers to measure your clearances. You could use some plasti-gauge and see what the clearances are, although this isn't very accurate. You could measure, get new main bearings, re-measure, and they should at least be tighter.
I'd put a new oil pump in it too.
Re: 360 losing oil pressure when reved up. [Re: GTX MATT] #327570
03/26/14 10:40 PM
03/26/14 10:40 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I would 2nd the worn main bearing theory, I've been there too
Re: 360 losing oil pressure when reved up. [Re: GTX MATT] #327571
03/26/14 10:59 PM
03/26/14 10:59 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
wow it has been 5 years I pulled the motor out back when I had the oil pressure problem and dropped in a temporary motor, now the temporary motor is needing replaced. since it was worn out when I got it. but this 360 is a good motor and I didn't want to screw it up. I have owned it since it only had 30,000 miles on it. now I need to fix it and get it back in my truck.
I don't have a bore mic, I do have a cheap set of digital calipers.
I will pull the caps off and get pictures, I will mark the caps to make sure I get them back on the right place. probably tomorrow.
thanks
Re: 360 losing oil pressure when reved up. [Re: dirt] #327572
03/26/14 11:34 PM
03/26/14 11:34 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Old Quaker Sludge oil used to cause lots of that years ago. Gotta love the old paraffin based oils.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 360 losing oil pressure when reved up. [Re: GTX MATT] #327573
03/27/14 09:34 PM
03/27/14 09:34 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
took some pictures of the main bearings. there was some small groves In the bearings but didn't seem to be any on the crank.
Re: 360 losing oil pressure when reved up. [Re: dirt] #327574
03/27/14 09:39 PM
03/27/14 09:39 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
number one
Page 1 of 3 1 2 3
