2003 2500 Ram dash
#3275121
12/09/24 05:32 PM
12/09/24 05:32 PM
Posts: 877 lancaster,california
johnnycuda
Hey guys, I hear this is a pretty common issue, my 2003's dash/gauge cluster stated shutting off, then turning right back on, just the gauges, truck kept running, AC, stereo, programmer, head lights etc, just the gauges, when it turned back on the door buzzer/bell etc would sound off again each time, at first was once in a while, but there was times where it would do it repeatedly over and over. A few months ago, had a issue with batteries, noticed the strands of the cable that showed at the ends were looking corroded, got a cable kit from a place in Az, was nice kit, had extra grounds etc, had it installed with two new batteries, I don't drive it much anymore, but the gauges haven't been doing that but the odometer just shows 6 dashes - - - - - - instead of the mileage, and dash says "service 4x4", but it is not a 4wd. Should I pull the cluster and have the back soldered as I have read on other sites/posts?, I am looking to drive cross country moving next year, and want to make its all good, truck has about 175,000 on it. Thanks in advance,
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: 2003 2500 Ram dash
[Re: J_BODY]
#3275642
12/12/24 12:51 PM
12/12/24 12:51 PM
johnnycuda
Yeah, I had ordered a rebuilt gauge cluster thru CarQuest back when this first started happening, waited a month, nothing, called Dorman, they had no cores to rebuild and said if I sent one in it would be sent to oldest order they had. I did find a couple places online that repair them, one is Circuit Board Medics, plan to pull the cluster one weekend and send it off, just had carpal tunnel surgery, so waiting for the that to get back to normal.
[Re: Prodart440]
#3275846
12/13/24 02:00 PM
12/13/24 02:00 PM
johnnycuda
Thanks, mine started just having 6 dashes where the odometer numbers would be, bright, no fading. Also, mine is showing "service 4x4 " even though it's not a 4wd, weird. Yep, thats the same I contacted about sending it in when the cluster kept turning off and then come back on, repeatedly.
