Trans cooler duct out of scrap
#3274466
12/06/24 05:22 PM
12/06/24 05:22 PM
Posts: 10,111 MI, usa
dvw
MI, usa
Instead of adding a cooler fan . Decided to duct between the radiator and the cooler. Had some left over aluminum from a prevous trailer repair. Made a homemade brake using a press and some 2" steel blocks. Broke out the square cardboard, siccors, tin snips . And not to forget. The trusty $15 Harbor Frieght electric shear. Took awhile to make templates as the car is all together. Now it'll pull air without vehicle movement. Hopefully this helps when you have to make 3 runs in less than an hour. Doug
Re: Trans cooler duct out of scrap
[Re: HardcoreB]
#3274565
12/07/24 09:38 AM
12/07/24 09:38 AM
Posts: 3,317 West Coast, USA
jbc426
West Coast, USA
Crafty! But that's going to add 1/2 pound to the front of the car! LOL, Beautiful work! On a more serious note, is the new shroud contacting/rubbing on the radiator fins?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#3274567
12/07/24 09:48 AM
12/07/24 09:48 AM
dvw
MI, usa
Crafty! But that's going to add 1/2 pound to the front of the car! LOL, Beautiful work! On a more serious note, is the new shroud contacting/rubbing on the radiator fins? No it has 3/16" clearance everywhere. I'll monitor it. If it shows any signs of contact. Then the clearance can be increased. Didn't weight it but been using this same aluminum (.030") for fan mounting, fan shrouds, airpans, It's pretty stiff wihen it has a bend in it. Doug
[Re: moparx]
#3274621
12/07/24 12:57 PM
12/07/24 12:57 PM
dvw
MI, usa
very nice ! will you be possibly considering a fan for the cooler in the future ? Shouldn't need one. That's why I built the duct. It has a dual fan set up out a late model Charger. On 16 volts you could swear they could pull the car forward. Doug
[Re: dvw]
#3274774
12/08/24 11:09 AM
12/08/24 11:09 AM
Posts: 20,742 north of coder
moparx
Buying your homeless and unwanted bolt on battery terminals
interesting use of the late model charger fan setup. i am considering that setup [if and] when i build a more potent engine for my charger. that looks like a good fit and choice.
[Re: moparx]
#3274803
12/08/24 01:07 PM
12/08/24 01:07 PM
jbc426
West Coast, USA
interesting use of the late model charger fan setup. i am considering that setup [if and] when i build a more potent engine for my charger. that looks like a good fit and choice. Just make sure you don't get the recalled ones.
[Re: jbc426]
#3274808
12/08/24 01:42 PM
12/08/24 01:42 PM
dvw
MI, usa
interesting use of the late model charger fan setup. i am considering that setup [if and] when i build a more potent engine for my charger. that looks like a good fit and choice. Just make sure you don't get the recalled ones. Been in the car 13 years. Doug
[Re: dvw]
#3274816
12/08/24 02:33 PM
12/08/24 02:33 PM
jbc426
West Coast, USA
Good to hear. The recall seams to afflict only the late model versions from 2011 to 2016. As with most recalls, there was not a 100% chance of failure.
"According to available information, late model Dodge Chargers from the 2011-2016 model years were subject to a cooling fan recall issued by FCA US LLC (Chrysler), affecting vehicles manufactured between August 23, 2010, and January 7, 2016; you can check your specific vehicle by contacting Chrysler customer service with the recall number "S03". Key points about the recall:
Affected vehicles: 2011-2016 Dodge Chargers
Issue: Potential problem with the cooling fan motor Action required: Contact your local Dodge dealer to get the cooling fan inspected and repaired if necessary."
[Re: dvw]
#3275020
12/09/24 12:15 PM
12/09/24 12:15 PM
Posts: 23,849 Here
jcc
No soup for you!!!
No soup for you!!!
Here
" Not it'll pull air without vehicle movement."
How so. the electrics will pull air when stopped. Your best "trick" here IMO, adding the cooler's lip spoiler. Probably a lot of turbulence in that entire area, but regardless you will be ahead of the game as a result of this project.
I forbid my content here from being learned and used by artificial intelligence systems.
[Re: jcc]
#3275037
12/09/24 01:06 PM
12/09/24 01:06 PM
dvw
MI, usa
How so. the electrics will pull air when stopped. Your best "trick" here IMO, adding the cooler's lip spoiler. Probably a lot of turbulence in that entire area, but regardless you will be ahead of the game as a result of this project. Typo. corrected "now it will pull air with no vehicle movement" Doug
[Re: dvw]
#3275187
12/09/24 11:35 PM
12/09/24 11:35 PM
Posts: 44,056 Bend,OR USA
Cab_Burge
How high were you seeing on your tranny temps?
[Re: moparx]
#3275257
12/10/24 12:02 PM
12/10/24 12:02 PM
Posts: 23,849 Here
jcc
No soup for you!!!
No soup for you!!!
Here
what temperature does atf start to break down, 260 or so ? what is the optimal operating temperature of atf ? I remember reading there is degradation observable for every 10F, now if there is a cliff, I don't know if or where.
