Re: Increasing hot oil pressure?
[Re: mopar dave]
#3270875
11/17/24 09:46 AM
11/17/24 09:46 AM
Posts: 1,438 Loudoun County, VA
Brad_Haak
Loudoun County, VA
To the best of my recollection, here's everything I did - took new pump out of box - sprayed it w/ brake cleaner externally and internally - tightened small bolts that attach the rotors to the rest of the body - removed bypass valve to verify spring type, inspect, and verify smooth movement of pressure relief valve after oiling it; compared to pump I just removed and noticed no differences - poured oil into rotors and spun to verify freedom of movement; compared to pump I just removed and thought it "felt" different, but hard to explain... - reinstalled bypass valve w/ original black spring that came with it - installed oil pump - pre-oiled new K&N filter and installed - fired up engine just long enough to see it wasn't building any pressure (ZERO) - pulled distributor & oil pump drive; no issues w/ oil pump drive seen - chucked up pump priming rod and went thru a couple of rounds of priming the pump; noticed the pressure was only going to about 20 PSI which ASSumed was because of the low RPM of the drill... but still didn't make sense, especially cuz the oil was cold - reinstalled oil pump drive & distributor - fired up engine just long enough to see it was only hitting about 20 PSI peak, but would then start dropping At that point it was about 8:30 PM, so I called it a day and took the dog for walk. Figured I'd consider what to do "tomorrow" (today) and go from there... or not, depending upon how I feel. Oh, I painted the new pump black cuz I couldn't find any of the Street Hemi orange I had used to paint the rest of the engine previously. I'm sure that's the problem... f-ing Emo oil pumps are so tempermental
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3270899
11/17/24 11:39 AM
11/17/24 11:39 AM
Posts: 2,813 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Ok, you have a new Melling M-63HV oil pump on it in the standard configuration. The oil drive is turning it. We have to assume it works and the gauge is reading true. So, a new oil pump, if the oil pickup is submerged in oil, and has no air leaks on the suction side, will pump a massive amount of oil. So, I only see 2 possibilities here. Either it has an internal oil leak on the pressure side (and it's big), or it is sucking air. It can suck air from a cracked oil pickup tube (above the oil level), a bad gasket seal between the oil pump and the block, or as stated above, a bad o-ring seal on the drive boss that sticks into the block. Yes, there is other weird and strange things that can happen but I would think in 99% of cases it would be one of those things.
2011 Drag Pak Challenger
[Re: Brad_Haak]
#3270910
11/17/24 12:50 PM
11/17/24 12:50 PM
Posts: 18,065 S.E. Michigan
ZIPPY
S.E. Michigan
As a quick check that doesn't cost alot, try a different oil filter. Put the K&N upside down in a clean plastic bag, and reuse it later if it is still good.
Anecdotal nonsense: A friend (who I know personally and trust to not BS me), had 0 oil pressure after an oil change with one. It's probably not that, but it is worth eliminating, in case you didn't already do that and I missed it.
Definitely try at least two gauges before getting into it too far.
I always have to use a thicker substance there like vaseline or grease, and have had no luck at all pouring oil into the pump. I can never get them to prime with oil alone.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3271276
11/19/24 12:07 PM
11/19/24 12:07 PM
Brad_Haak
Loudoun County, VA
FWIW, I won't have any updates on this for probably 2-3 weeks cuz I need to focus on some other things for a while. Thx
[Re: CSK]
#3271671
11/21/24 12:20 PM
11/21/24 12:20 PM
Brad_Haak
Loudoun County, VA
Absolutely; I'm sure anything I find will result in a post either here or in the For Sale section...
[Re: Brad_Haak]
#3274984
12/09/24 09:50 AM
12/09/24 09:50 AM
Brad_Haak
Loudoun County, VA
No updates cuz I broke & dislocated my left index finger about 3 weeks ago. Typing is bad enough, but wrenching is pretty much a no-go for now...
[Re: Brad_Haak]
#3275292
12/10/24 03:07 PM
12/10/24 03:07 PM
Posts: 19,637 Las Vegas
Al_Alguire
Las Vegas
No updates cuz I broke & dislocated my left index finger about 3 weeks ago. Typing is bad enough, but wrenching is pretty much a no-go for now... Getting old is heck...I have a torn rotator cuff and labram from putting a trans in my car..I fell your pain
[Re: moparx]
#3275404
12/11/24 07:57 AM
12/11/24 07:57 AM
Posts: 2,139 MD
RTSE4ME
MD
i know how tough wrenching can be with "hurting places", as having MS, i have to deal with this on an everyday basis.
Wrenching can be good therapy. Therapy can't simulate a lot of things wrenching requires. I lost fine motor skills on my left hand, secondary progressive here.
[Re: RTSE4ME]
#3275410
12/11/24 08:47 AM
12/11/24 08:47 AM
Posts: 2,930 Pattison Texas
CSK
Pattison Texas
Wrenching can be good therapy. Therapy can't simulate a lot of things wrenching requires. I lost fine motor skills on my left hand, secondary progressive here. I to Have MS, I try to keep doing small projects & keep moving, BUT getting older WITH the MS pain is,,, well ,,,, just a PAIN lol, I laugh at myself so I dont cry , My Charger is names Brain Damage for a reason
[Re: CSK]
#3275434
12/11/24 11:03 AM
12/11/24 11:03 AM
Posts: 20,742 north of coder
moparx
Buying your homeless and unwanted bolt on battery terminals
Wrenching can be good therapy. Therapy can't simulate a lot of things wrenching requires. I lost fine motor skills on my left hand, secondary progressive here. I to Have MS, I try to keep doing small projects & keep moving, BUT getting older WITH the MS pain is,,, well ,,,, just a PAIN lol, I laugh at myself so I dont cry , My Charger is names Brain Damage for a reason how well i know what you go through Charlie ! therapy is good, but wrenching or working with your fingers helps tremendously with motor skills. and yes, it's a REAL PAIN for sure ! i help myself by saying : "no matter how bad i have it, people out there have it worse than me, and those folks are the ones to be concerned about !"
[Re: dvw]
#3275442
12/11/24 11:33 AM
12/11/24 11:33 AM
moparx
When I feel pain? Think to myself my body is telling me a lie. And keep going. Doug kind of what i have been doing for years. however, the older i get, the shorter the time period i can do this before it just becomes too much............ it's better than the "alternative" , i guess.........
[Re: moparx]
#3275467
12/11/24 12:58 PM
12/11/24 12:58 PM
Al_Alguire
Las Vegas
I thought pain was natures way of reminding us that we were still alive.
FWIW I have been dealing with the torn rotator cuff and labrum since May. Now its race season so surgery will have to wait til after April.
[Re: Al_Alguire]
#3275468
12/11/24 12:59 PM
12/11/24 12:59 PM
Posts: 44,056 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#3275510
12/11/24 03:55 PM
12/11/24 03:55 PM
Posts: 10,169 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I had oil pressure issues years ago. Came and went as throttle was applied. Got home, pulled rhe pan, and there was that rag, in the pan sump, the one i thought i had removed!
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
