8 .75 compleat brake drum hardware? #3274946
12/09/24 05:49 AM
12/09/24 05:49 AM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
Is there a kit for everything needed to compleat a brake setup?
Buying drums and shoes no biggie. But all the rest.....
All I have is the backing plates and emergency brake cables on this rear nothen else to make a compleat drum brake setup
Seen that trying buy sep. Wanted k own if was round hole or square hole? So I'd like to buy a compleat package
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: 8 .75 compleat brake drum hardware? [Re: toplescuda] #3274954
12/09/24 07:26 AM
12/09/24 07:26 AM
The Summit
Phoenix Offline
Phoenix  Offline
The Summit
I was certainly able to buy these kits from O'Reilly's several years ago...
Or maybe not quite all you need. Missing will be the e-brake lever and the piece which goes between that lever and the trailing brake shoe. All the clips, springs, washers and retainers are in there.
I think these are interchangeable with the brakes on the later models, too, and I recently bought such a kit from Autozone. This was for the 11" brakes on a 1999 RAM van with the 9ΒΌ" rear axle, it cost about $11.50.
Re: 8 .75 compleat brake drum hardware? [Re: Phoenix] #3274982
12/09/24 09:43 AM
12/09/24 09:43 AM
MD
floyd Offline
floyd  Offline
MD
Bill Rolik has a well organized selection of brake kits
https://www.billrolikenterprises.com/products.php?cat=14
Re: 8 .75 compleat brake drum hardware? [Re: floyd] #3275099
12/09/24 04:02 PM
12/09/24 04:02 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
The emergency brake levers can also be found sometimes in the "help" sections at Advance and the like... twocents
...FAFO...
Re: 8 .75 compleat brake drum hardware? [Re: skicker] #3275102
12/09/24 04:11 PM
12/09/24 04:11 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
What's the differance in say 70 cuda. And 71-74
1971 charger
Re: 8 .75 compleat brake drum hardware? [Re: toplescuda] #3275107
12/09/24 04:34 PM
12/09/24 04:34 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I'm not a numbers guy as far as something being correct...
I have bought the emergency brake levers in both 10" and 11" depending on what your using... twocents
I do know there is a LH and RH bracket and the two are different...just opposites...
...FAFO...
Re: 8 .75 compleat brake drum hardware? [Re: skicker] #3275138
12/09/24 06:52 PM
12/09/24 06:52 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
10" or 11"
A body rear or non- A body rear?
Early ones didn't come with self adjusters, IIRC.
Doc Diff has kits
https://www.doctordiff.com/drum-brake-rebuild-kit.html
