8 3/4 set up
#3274900
12/08/24 08:31 PM
12/08/24 08:31 PM
Posts: 574 Kentucky
clovis
Kentucky
I am going to go ahead and apologize as I know this has been discussed a lot but after a couple of days of searching I can’t seem to find anything with a more definitive guide with weight, converter and HP.
Bought a 65 Plymouth that I am going to try and race next season. I have a couple of options for an engine but was curious about what will live with the 8 3/4 (489). I am assuming I am going to weight in at 3700+. I can take the engine out of my Duster which is probably 530-550 hp- it goes 11.00 (1/4) at 3350 lbs, so I am guessing it will be an 11.50 car. The converter is about 5800. Would the 8 3/4 live ok in that environment?
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: 8 3/4 set up
[Re: clovis]
#3274901
12/08/24 08:46 PM
12/08/24 08:46 PM
Posts: 20,416 Park Forest, IL
slantzilla
Park Forest, IL
Maybe. Especially if you put in a new ring and pinion every 150 runs.
Re: 8 3/4 set up
[Re: Neil]
#3274933
12/09/24 12:01 AM
12/09/24 12:01 AM
Posts: 12,733 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I've known people who used them in lighter A-body and F-body cars that went pretty fast without hurting them for years. Excessive weight, stick shift, trans-brake, ect. is likely not good. Can always sell it before you break it, and use that money to go to something more durable. Don't forget radials on a good track.
Re: 8 3/4 set up
[Re: clovis]
#3274977
12/09/24 09:20 AM
12/09/24 09:20 AM
Posts: 13,283 Benton, IL.
DaveRS23
Master of nothing...
Benton, IL.
If you hook, hitting the 8 3/4 at 5,800 with 500+hp is going to hurt it sooner or later. I have always ran 8 3/4s and like them. But while it would otherwise live with that combo for a long time, it won't like that hit.
I run 3.91s in my 3,900lb Cuda behind the 540 HEMI. I can run it for years on the street with drag radials with no issues until I start hooking at the track and shocking it hard. Dead hooking will hurt it.
And don't forget to get good axles, too.
Master, again and still
Re: 8 3/4 set up
[Re: clovis]
#3274979
12/09/24 09:23 AM
12/09/24 09:23 AM
Posts: 13,599 Marion, South Carolina [><]
an8sec70cuda
I think you're right about the point of maybe, maybe not, lol. It will probably live for a while.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
Re: 8 3/4 set up
[Re: topside]
#3275038
12/09/24 01:11 PM
12/09/24 01:11 PM
Posts: 10,111 MI, usa
dvw
MI, usa
I've had the same 4.30 8 3/4 chunk in several cars. For years it's been in my 11.0@3385lb street car. Hundreds of passes on slicks. To be honest I've never broken an 8 3/4 R&P. Friends 65 Belvedere runs 11.4, Same 4.10 chunk for at least 15 years, It was used when I gave it to him. Doug
Re: 8 3/4 set up
[Re: dvw]
#3275049
12/09/24 01:36 PM
12/09/24 01:36 PM
Posts: 126 pa
gregcharger72
pa
I've had the same 4.30 8 3/4 chunk in several cars. For years it's been in my 11.0@3385lb street car. Hundreds of passes on slicks. To be honest I've never broken an 8 3/4 R&P. Friends 65 Belvedere runs 11.4, Same 4.10 chunk for at least 15 years, It was used when I gave it to him. Doug Same here, 4.30 , 8 3/4,spool , 30x9 slick 3700lbs car 1.45 60' times, hundreds of passes. In 25 years only broke 1 R&P. 742 housing if that matters.
Re: 8 3/4 set up
[Re: Neil]
#3275096
12/09/24 03:31 PM
12/09/24 03:31 PM
Posts: 574 Kentucky
clovis
Kentucky
Thanks for the reply, for those that responded that are running an 8 3/4, what are your or friends set-ups - axles, case, gear, pos or spool , backlash. I’ve read a few places were it seems there is a preference toward the 742 cases. I currently have a 489 with a 4.11. I haven’t taken it down yet to see axles or if the crush sleeve has been eliminated. I would be surprised if it had anything other than 30 spline axles.
Re: 8 3/4 set up
[Re: racerx]
#3275318
12/10/24 04:58 PM
12/10/24 04:58 PM
Posts: 11,715 W. Kentucky
justinp61
W. Kentucky
I rebuilt and sold the 8 3/4, then ordered a new Strange S-60. If I were doing it today i'd go with a 9". Curios why? More brake and gear options, not to mention used third members and cases.
Re: 8 3/4 set up
[Re: Neil]
#3275340
12/10/24 07:27 PM
12/10/24 07:27 PM
DaveRS23
Benton, IL.
It's Motortrend so some of their info you have to take with a grain of salt. Passenger car Dana 60 axles may actually be somewhat more difficult to locate I would think? I've never tried looking for one, but I suspect you can't just find one in a pick your part junkyard anymore. I know junkyards here still have them in various older pickups so finding one of those is not too hard, but those don't just plug and play into an old car. Neither do the phord rears. Unless it's another phord. And this web site is, by the way, about Mopars.
Re: 8 3/4 set up
[Re: DaveRS23]
#3275346
12/10/24 08:03 PM
12/10/24 08:03 PM
Posts: 13,257 aZLiViN
J_BODY
aZLiViN
…..and you’re in the “race” section. We do what we want!
