Re: Milodon dual oiling question
[Re: dvw]
#3274037
12/04/24 11:23 AM
12/04/24 11:23 AM
Posts: 122 western iowa
Z_Z
western iowa
As long as it's apart this far. Check the O ring on the boss the slides into the block on the oil pump housing. Doug Thanks Doug, I'll look at that when I take it back apart..
[Re: rickraw]
#3274039
12/04/24 11:31 AM
12/04/24 11:31 AM
Z_Z
western iowa
That’s not a o-ring fitting. Thats a bulkhead fitting, that could b ur problem. Ok guess another thing i need to look for..thank you rick.
[Re: Z_Z]
#3274074
12/04/24 02:01 PM
12/04/24 02:01 PM
Posts: 3,245 Michigan
A727Tflite
Sorry guys for late replies, sorry no clue on drill speed, it's a habor freight that's well over 10 years old.
Is it possible, maybe I put the side cover with the impeller's back in wrong?
The lines feel like the have pressure on them. I will try to prime and spin the motor at the same time.
It's a 21200 milodon pump, I have attached a picture of what the o rings looked like.
Provide a better picture of that pump cover. Looks bad in this image.
[Re: Z_Z]
#3274241
12/05/24 12:36 PM
12/05/24 12:36 PM
Posts: 5,773 Hot Rod Ridge
FastmOp
Hot Rod Ridge
Could it be sucking the pan up to the bottom of the pickup?
Hi ZZ long time no see. Post some car pics.
You been to the track with it?
[Re: Z_Z]
#3274280
12/05/24 03:41 PM
12/05/24 03:41 PM
Posts: 13,599 Marion, South Carolina [><]
an8sec70cuda
blue RR...last 6 of the vin wouldn't be 253495 would they?
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: Z_Z]
#3274289
12/05/24 04:11 PM
12/05/24 04:11 PM
an8sec70cuda
Nevermind...the one I'm looking for was no AC auto on the column. My dad's RR he bought new ended up somewhere out there last he heard. If I could ever find it, I'd love to have it.
[Re: Stanton]
#3274569
12/07/24 09:57 AM
12/07/24 09:57 AM
Posts: 9,172 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Through thise pump gears don't look great. Unless the clearance is way out of spec they are not the problem. Look at these gears. Broken valve spring happened mid summer. Cleaned out the pan. Ran the car all season after swapping springs. Over the winter motor was serviced. It had held 70 psi at speed . Doug Pumps are cheap, why would you want to put those back in a motor !!
[Re: dvw]
#3274575
12/07/24 10:19 AM
12/07/24 10:19 AM
Posts: 740 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
Through thise pump gears don't look great. Unless the clearance is way out of spec they are not the problem. Look at these gears. Broken valve spring happened mid summer. Cleaned out the pan. Ran the car all season after swapping springs. Over the winter motor was serviced. It had held 70 psi at speed . Doug Bingo! That is not your issue, it is an issue, but it's not going to cause a drop in pressure when running. You are looking for something that allows good pressure when static and low pressure when running. It's either one of two things, If you have a restriction in the oil pump pickup (IE rtv stuck in the screen). Or you have a leak(s) that only happen when the engine is running. I have a feeling that you will find the issue once you pull the intake and valley pan, run the oil pump with a drill and crank the engine with the starter. One other thing to look at, is the oil pump drive gear pinned to the shaft? Joe
Without Data, you’re just another guy with an opinion.
[Re: Z_Z]
#3274588
12/07/24 11:23 AM
12/07/24 11:23 AM
sr4440
Central TEXAS!!!!
No, the gear on the intermediate shaft. Because you primed the pump with a drill and are now trying to drive it with the intermediate shaft. If the drive gear is slipping on the shaft, it will cause the issues you are having.
[Re: Z_Z]
#3274605
12/07/24 12:05 PM
12/07/24 12:05 PM
Posts: 19,637 Las Vegas
Al_Alguire
Las Vegas
As bad as the pump looks it is NOT the issue. You have pressure while using a drill but it goes away running. Something internally is causing the loss of oil pressure not the pump.
If the distributor goes n flush with the block there is nothing wrong with the drive engagement. Still back to something going on internally to cause it to loose pressure when running.
I would try priming it while cranking the engine and see what happens then. Fact remains it has pressure with a drill. So the pump works. It is a question of whats going on with the engine running.
