Re: lug nuts getting loose, non- mopar
[Re: Andrewh]
#3274372
12/06/24 06:36 AM
12/06/24 06:36 AM
Posts: 5,001 new berlin wisconsin
Mr T2U
i assume you have alloy wheels. to me 80ftps seems low. do these cars have smaller than normal wheel studs? i checked the specs and they say 72-87 i torque a alloy wheel. i torque alloys to 100 ft lbs and steel wheels to 80 ft lbs on cars and 120 ft lbs on light duty trucks. never had a problem. these are newer cars from 2000 and up. i also have read in chat rooms and they seem to say tighten in steps, 50-60-80, to 80 ft lbs. waste of time in my mind. i just double check torque and torque to specs a second time. all i can say is try 90 ft lbs and see what happens.
if the one loosening is the same. maybe a possibility this wheel stud isn't in the hub completely?
perception is 90% of reality
[Re: A12]
#3274406
12/06/24 11:10 AM
12/06/24 11:10 AM
Posts: 10,646 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Issue with that hub since its about all you have not replaced?
How are you tightening them? In two steps? Are you re torquing after a few miles? I know the srt cars are a different style being the tapered like bolt but I always re torque just after a few miles and they take it to reach the proper tq. On those lugs I go 105/110lbs and I know some go 120lbs.
Good brand rims?
STOP POTATO HATE!
[Re: Andrewh]
#3274428
12/06/24 12:45 PM
12/06/24 12:45 PM
Posts: 11,006 Freeport IL USA
poorboy
Freeport IL USA
I would start by marking the stud, the lug, and the wheel, then move that one lug to a different stud on the wheel to see if its the stud, or the lug that is a problem. Then just for fun, I would rotate the wheel so that wheel hole is on a different stud, with a different lug nut to be sure the problem isn't the wheel.
Also note, new parts these days doesn't necessarily mean the parts are good.
I believe 80 is pretty low torque for alloy wheels. I do 90 on mine, and you are suppose to retorque them in less then 50 miles.
The next question would be just how much more does the lug tighten a day later?
I had one hub, one time, that had a hairline crack on the mounting surface near one stud. Each time the lug was torqued, the stud was moving in the hub.
[Re: Andrewh]
#3274429
12/06/24 12:46 PM
12/06/24 12:46 PM
Posts: 21,608 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
I had an issue with a couple front lug nuts backing off a slight amount on some cast aluminum wheels that kept doing it for several days until it stopped. Whenever the wheels came off the vehicle for any reason I took a torque wrench with me and would check them once a day until they stayed tight. They never backed off enough to make the wheel loose they just kept loosing 10 foot pounds or so after so many miles. I thought it was the cast wheels were soft, and that may have been some of it, but It wasn't until I switched out the tire store sourced chrome lug nuts (likely the cheapest bulk stuff they can find) for some better quality McGards that the lugs actually stayed tight. When you put both types of lug nuts on by hand the McGards have a much tighter fit to the stud vs the the cheap tire store ones. The tire store ones spun on almost too easy and had a small amount of jiggle to them all the way until they got close to making contact with the rim.
I had another old car years earlier and I put McGards on that with new aluminum mags at the same time and they always held torque perfectly. Remembering that is what let me to switching out the lug nuts on the other vehicle that I was having some issues with.
[Re: Andrewh]
#3274547
12/07/24 07:13 AM
12/07/24 07:13 AM
Posts: 6,540 ohio
ruderunner
ohio
Are these stock parts or fancy aftermarket wheels?
I've seen incorrect lugs and studs where the threads bottom out before they actually clamp the wheel tightly.
Run the nuts down without a wheel and see how close they get to the flange.
Also, check that there's not excessive rust or debris caught between the rotor and hub.
Angry white pureblood male
[Re: topside]
#3274638
12/07/24 01:37 PM
12/07/24 01:37 PM
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Although a different lug type, my srt cars like 110 and I know a few who go 120. I still maybe question the hub itself? Is there like a moog hub that comes with the studs?
STOP POTATO HATE!
[Re: Andrewh]
#3274655
12/07/24 02:38 PM
12/07/24 02:38 PM
Posts: 10,667 Rittman Ohio
fourgearsavoy
Rittman Ohio
The only thing that usually happens is there could be rust between the hub and brake rotor surfaces. I've been an import tech for close to 40 years with Honda and Toyota and they really don't have many issues with stock rims and nuts that came on the car. I have always put a few drops of oil on the threads or spray on white grease to the hub and studs. One of the younger techs figured I have installed over 1.5 million lug nuts in my first 30 years. I don't use torque sticks and only use a torque wrench on aftermarket wheels. I tighten all my wheels with an impact set on low in a star pattern and hit them all one more time in a circle. Never had a comeback or complaint for loose wheels in the thousands of cars I've worked on. I never put nuts on a dry stud and I think it's important to get the proper torque and clamping force on the rim. Double check with the dealership that you have the proper nuts for the EXACT rim you are using Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Andrewh]
#3274675
12/07/24 03:45 PM
12/07/24 03:45 PM
fourgearsavoy
Rittman Ohio
Make sure you also clean between the brake rotor and hub too
