Wiw 440 short block #3274107
12/04/24 04:33 PM
12/04/24 04:33 PM
Ky
moparmafia Offline OP
Ky
I have a 440 I bought from a friend a couple years ago and I’m guessing it’s a warranty block. It has no vin on the pad by the pan rail. It’s .040 over steel crank and doesn’t have a lot of miles since being rebuilt. It is dated 1-73. I was curious since there’s no vin does that increase the value and what is it worth? I sold the car I was gonna use it in so I’m thinking of letting it go. Thanks for any info
Re: Wiw 440 short block [Re: moparmafia] #3274122
12/04/24 07:22 PM
12/04/24 07:22 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Complete 440 core engines are around here that appear on CL are $700 - $1000 if they have all the accessories. If the one you have does not need to be rebuilt, but is missing the heads and intake ect then maybe $500 or so. If I was the buyer I would want to have some verification that it's good inside like pulling the main caps off to look at it, and turn it over to look at the bores ect. The more you can do to prove it's all good the better $$$ you will be able to get out of it.
Re: Wiw 440 short block [Re: Neil] #3274158
12/05/24 12:14 AM
12/05/24 12:14 AM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
iagree
Re: Wiw 440 short block [Re: migsBIG] #3274233
12/05/24 12:11 PM
12/05/24 12:11 PM
an8sec70cuda Offline
iagree and I don't think the blank VIN pad matters since it's a '73 block. twocents
Unless it has good pistons in it, I'd say the previous estimate is close.
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
