Re: Ever had an MSD 6AL just die on you?
[Re: A727Tflite]
#3273720
12/02/24 06:43 PM
12/02/24 06:43 PM
Posts: 10,654 Rittman Ohio
fourgearsavoy
Rittman Ohio
Yeah that is how they test your shut-off switch they flip it off while it's running to make sure it shuts off. If it doesn't then it's pretty much useless. My 6AL is about 25 years old since I sent it to MSD when I bought it used to have them extend the wires and check it out. I am aware of how voltage spikes can damage electronic devices and I'm not saying it can't happen but tech inspectors do this to thousands of cars every weekend. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#3273797
12/03/24 06:21 AM
12/03/24 06:21 AM
Posts: 3,014 A shed in England
Tig
A shed in England
Yeah that is how they test your shut-off switch they flip it off while it's running to make sure it shuts off. If it doesn't then it's pretty much useless. My 6AL is about 25 years old since I sent it to MSD when I bought it used to have them extend the wires and check it out. I am aware of how voltage spikes can damage electronic devices and I'm not saying it can't happen but tech inspectors do this to thousands of cars every weekend. Gus The MSD tech guy told me what kills them is reattaching the battery cable while running - if I recall he said it goes full field while disconnected then zaps the box when reconnected. I’m no electrical expert, still haven’t forgot my first electric shock. Yep they check it the same over here too. The battery isolation (kill) switch should turn everything off and the engine should stop. Removing the battery cables while the engine is running will still allow the engine to run IF the alternator field circuit isn't interrupted. This can cause voltage spikes as the battery acts as a type of voltage "buffer". I've had no issues with either an analogue 6AL or a Grid when the kill switch is checked but on the grid we do have a MSD filter (capacitor), which we also take the voltage supply for the Racepak from. This filters out any RFI or relay spikes though we've fitted flywheel diodes to the relays where possible.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: A727Tflite]
#3273829
12/03/24 11:25 AM
12/03/24 11:25 AM
Posts: 13,581 Marion, South Carolina [><]
an8sec70cuda
So if your kill switch works properly, this won't be an issue.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: an8sec70cuda]
#3273845
12/03/24 12:20 PM
12/03/24 12:20 PM
Tig
A shed in England
So if your kill switch works properly, this won't be an issue. Never had an issue, first started racing in '96 and they check it at least once every season. I'm always switching it on and off too but usually the car isn't running.
[Re: A727Tflite]
#3273989
12/04/24 06:38 AM
12/04/24 06:38 AM
Tig
A shed in England
Yeah, I can see that happening, sorry to be a bit long winded here. Disconnecting the battery while the alternator is charging the battery, will spike the voltage as the alternator is unloaded. Full fielding is some thing auto electricians do to check / test alternators, it involves bypassing the field regulator and applying 12v to the field which can bump the o/p to over 28v. According to MSD, their ign units, (at least the newer boxes) have a built in regulator and are recommended to work from 9 to 18v. Momentary / short periods of 24v (jump starting) are ok. I have an old (1996) 6AL that has been used on various cars / engine combo's, it has it's own battery supply cables so I'm guessing that was around the time they changed.
[Re: moparx]
#3274066
12/04/24 01:10 PM
12/04/24 01:10 PM
Tig
A shed in England
one thing i NEVER do, is disconnecting the battery cable [either one] while the engine is running. if one needs to diagnose electrical problems, there are a multitude of better ways than doing this ! Unfortunately a battery isolation switch is an NHRA / FIA requirement if you want to race at "permit" meetings here in Europe and the UK, I think it's the same in the USA. There are ways to minimise any voltage spiking risks though. They usually check it with the engine running and it must cut power to the ignition, stopping the engine.
