318 or 340 Accel cable bracket? Vac Adv/emissions thingy #3273950
12/03/24 09:38 PM
12/03/24 09:38 PM
Omaha Ne
TJP Offline OP
TJP  Offline OP
Omaha Ne
Have the pictured bracket which I believe to be off a 340 4 sp application. Any confirmation on 318 or 340? paint color may not be original shruggy
And WIW smile
The Vac Adv. emissions thing ? WIW
TIA
Re: 318 or 340 Accel cable bracket? Vac Adv/emissions thingy [Re: TJP] #3273958
12/03/24 10:41 PM
12/03/24 10:41 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Top part looks like part # 0060 in here, which is a 68-73 340 throttle bracket. No pivot pin would be for a manual trans.
https://www.hoffmanswinnerscircle.com/14_fuel.htm
Re: 318 or 340 Accel cable bracket? Vac Adv/emissions thingy [Re: Neil] #3274044
12/04/24 12:03 PM
12/04/24 12:03 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Yup, LA stick throttle cable bracket.
Bottom photo is vacuum chingadera found on CA cars, attached to right of carb.
(IIRC, vac advance modifier, usually ripped off the cars by the 2nd day, and then a frantic search for it when CA smog inspections arrived...DAMHIK laugh2
