Re: Drag Week Mufflers?
[Re: topside]
#3273485
12/01/24 11:26 PM
12/01/24 11:26 PM
Posts: 4,678 Motor City
6PKRTSE
Motor City
I use Marmin flanges and clamps on my exhaust. 1 bolt on the clamps. Can be removed and installed in seconds.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Dragula]
#3273499
12/02/24 01:02 AM
12/02/24 01:02 AM
Posts: 43,986 Bend,OR USA
Cab_Burge
I bought and used a set of the early crimp steel stock type construction style Magna Flow 14 inch long oval x7.0 tall x 22 inches long overall (I think CRS) with 3.0 inch side inlets with straight through perforated 3.0 inch pipe exiting in the center. I was using a set of either Hooker 2.0 inch fenderwell headers for a BB in my Duster or maybe by then I had bought and switch to a set BB Hedman fender well headers with 2.0x3.5 inch collector . The muffs were mounted behind the rear end housing between the rear sub frame rails and the 1/4 panels with the short muff tailpipes exiting at the rear bumper, not real loud at part throttle cruise and not hurting the performance, that car would pick up from a 7.01 with them on to a 6.98 /6.99 .002 MPH gain with them completely removed from the car I wasn't able to buy a set of 3.5 inch crimp Magna Flow muffs and tail pipes back then IHTHs
[Re: Dragula]
#3273510
12/02/24 03:14 AM
12/02/24 03:14 AM
Posts: 3,473 Md.
carnut68
Md.
How about electric cut outs?
America First!
[Re: carnut68]
#3273518
12/02/24 06:02 AM
12/02/24 06:02 AM
Posts: 10,122 MN
JERICOGTX
MN
If you plan on removing the exhaust at the track, why not just run 2.5" exhaust, and keep it quiet for the drives? That is what Joel runs on his Coupe, and tailpipes all the way to the rear. We could easily talk in the car, while going down the road, and Joel normally couldn't hear a dump truck driving through a nitroglycerin plant. Joel runs V band clamps, and the hangers are on simple rubber hanger. It was my job to remove, and install the exhaust at the track, and could have it completed in under 5 minutes, one way or another.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3273557
12/02/24 09:58 AM
12/02/24 09:58 AM
Posts: 8,107 Tulsa OK
Bad340fish
Tulsa OK
I use a DynoMax UltraFlow 3". At 600HP my car doesn't go any faster with the cutouts open. It is a pretty reasonable noise level at cruise speeds in the 3000-3500RPM range.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3273674
12/02/24 04:14 PM
12/02/24 04:14 PM
Posts: 12,505 Taxes & Virus's R-US, NY
Dragula
At this point, I am not sure which engine the Cuda will have in it this summer. I have to pull the 512/400 from the Duster for a looksy and make sure all is good, like I usually do, although I think I have like 5 passes on it in total. And the Hemi may have to come out of the Cuda to update the car for full cage, not sure. Gonna work that out with AJ I think...
So I could mild up the cam in the 512/400 and put it in the Cuda and save the big 605 Hemi from all the abuse and see if I could even make Drag Week happen. Which is the way I am leaning at the moment. Not sure how fast the car would go with a mild 512 in it, probably only 10's.....But I would need headers, preferably Hookers...Either way, I would think 2.5 " is way too small. I have run as big as 3.5" turn downs and bullet mufflers...Those were way too loud. I can handle my current mufflers for local cruising, not sure how they are on long drives.
I have been slowly checking items off my Drag Week to do list since 2019 if you can believe that, and the cage is the big one. Everything else is done or already in process except new 315 drag radials and the rims. The wiring is in process, and I have new rims I am going to use for more appropriate 31x16 street tires.
So I don't know, maybe a set of simple Y-dumps off my current necked down 3" would be enough to not kill too much ET.....
[Re: Dragula]
#3273676
12/02/24 04:18 PM
12/02/24 04:18 PM
Posts: 13,581 Marion, South Carolina [><]
an8sec70cuda
A 3.5" system w/ a pair of good straight through mufflers like Dynomax Ultraflows or Hooker Max Flows would be pretty quiet and not kill much if any ET.
I have an H pipe system for my cuda w/ a pair of 4" Hooker Max Flow mufflers and turn downs at the rear axle. I actually don't like it b/c it's a lot quieter than I expected it to be.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: an8sec70cuda]
#3273763
12/02/24 10:33 PM
12/02/24 10:33 PM
6PKRTSE
Motor City
Mine are 3-1/2" with straight through Dynomax Ultraflows. However, not much for conversations until you get to the next destination....
[Re: Cab_Burge]
#3273907
12/03/24 06:09 PM
12/03/24 06:09 PM
Posts: 7,550 Minnesota
Hemi_Joel
Minnesota
You can make enough power to go down the road on the drives through a single 1 and 1/2-inch exhaust pipe. And you can build a very quiet system with two or two and 1/2 inch mufflers and pipes. So if you're going to take the exhaust system off at the track anyway, why suffer the noise going down the road for hours on end. Look at Mike Finnegan, bless his heart. He takes off his track exhaust and puts on his Street exhaust, and it's still so loud that him and his trunk monkey where headsets with noise suppressing mics just so they can talk to each other when they're 2 ft apart. Why? I built mine quiet because I don't need 600 horsepower to drive 80 mph down the freeway. With all of the discomforts of a drag and drive event, it's nice to eliminate one of them and have a quiet exhaust and be able to have a civil conversation with your trunk monkey.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#3273910
12/03/24 06:19 PM
12/03/24 06:19 PM
Posts: 23,698 Here
jcc
No soup for you!!!
No soup for you!!!
Here
Besides, your hearing is like sandpaper, it eventually wears out. And you one only get one set, and your grandkids will appreciate it if you take care of yours. Says the guy who raced stub open exhaust 2 cycle go karts as a kid and worked 5 decades of rock concerts.
I'm with Helmuth Hübener, and no soup is being served today.
[Re: JERICOGTX]
#3273993
12/04/24 08:02 AM
12/04/24 08:02 AM
Posts: 5,049 new jersey usa
11secdart
new jersey usa
Try this guy : Herfurth Aluminum Racing Mufflers .. he custom builds mufflers and exhaust systems including for some drag week cars . He is a fellow index racer and since my TTI H pipe fits so poorly I am going to him in the spring for a complete system .
[Re: jcc]
#3274019
12/04/24 10:28 AM
12/04/24 10:28 AM
Posts: 8,252 Plymouth, MI
Blusmbl
Plymouth, MI
Besides, your hearing is like sandpaper, it eventually wears out. And you one only get one set, and your grandkids will appreciate it if you take care of yours. Says the guy who raced stub open exhaust 2 cycle go karts as a kid and worked 5 decades of rock concerts. x2. I have a CDL and get my hearing checked through work. It was above average for my age for many years, then started to degrade, between motorcycles and the Plymouth with a loud exhaust for the last couple years. I put a smaller diameter system, tailpipes, and quieter mufflers on it this year just to help save my hearing, even though I don't care for how it sounds outside the vehicle quite as much. For the OP, I think you'd be okay with your current exhaust with cutouts, either the old school 3 bolt or v-band style. V-bands are so much nicer to work with though.
[Re: Bad340fish]
#3274027
12/04/24 10:37 AM
12/04/24 10:37 AM
Posts: 4,860 Wichita
GY3
Wichita
I use a DynoMax UltraFlow 3". At 600HP my car doesn't go any faster with the cutouts open. It is a pretty reasonable noise level at cruise speeds in the 3000-3500RPM range. We have the same ones and they work great for a street/strip car.
'63 Dodge 330
11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
