my sons 89 D350 cummins has lost the power steering fluid twice the last 2 days.It has new lines and there is no evidence of a leak. Could it go by the front seal and end up in the engine oil? Birdftracker
Is it possible that there's (or was) air in the system, and it's just working itself out?
i was thinking about the air working itself out as well, as i have had a few instances similar to that over the years. in my circumstances, the fluid didn't completely disappear, but turned up very low in the reservoir several times until it stabilized at the recommended level, then stayed there.
i determined it had to be an air issue, as no leaks could be found [just as the OP] and the steering operated as it should.
as i know nothing about the diesel engine, how would it be possible for the power steering fluid to leak into the engine ? is the pump driven by an engine shaft ?
curious to know.
![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
