Re: white foam square at gas pedal ?
[Re: buzz440]
#3271980
11/23/24 12:31 PM
11/23/24 12:31 PM
Posts: 20,585 north of coder
moparx
when i installed the new carpet in my 69 charger this spring, i put the foam square between the carpet and foam, correct or not. my thinking was the foam would act as a moisture "deterrent", keeping any moisture away from the carpet. however, i installed a "gasket" cut from a roll of gasket material the shape of the foam gasket, [slightly larger in fact] sealed to the floor with a thin smear of seam sealer, before the foam square, just to be absolutely sure no moisture would come through this area. i know this isn't correct by any stretch of the imagination, but that's what i did anyway. i also greased up the gas pedal studs with high temp copper anti-seize before i nailed down the pedal for the final time. i will more than likely never remove the pedal in the rest of my lifetime, but did so "just because".
[Re: fastmark]
#3272109
11/24/24 07:43 AM
11/24/24 07:43 AM
Posts: 6,452 ohio
ruderunner
ohio
In my experience, water on the floor of a vehicle is infinitely more likely to come from above the car than from underneath. As such, I try not to seal my floors watertight, let the water drain out. I've even gone as far as punching extra holes, A bodies can really use that.
Angry white pureblood male
[Re: buzz440]
#3272156
11/24/24 01:00 PM
11/24/24 01:00 PM
moparx
moparx, thanks for the reply but, in your reply did you mean to say; i put the foam between the (floor) and carpet ? because your answer says you put it between the foam and carpet.
later,BUZZ i goofed Buzz ! i should have said "between the carpet and floor".......... sorry !
