Re: white foam square at gas pedal ?
[Re: buzz440]
#3271980
11/23/24 12:31 PM
11/23/24 12:31 PM
Posts: 20,740 north of coder
moparx
when i installed the new carpet in my 69 charger this spring, i put the foam square between the carpet and foam, correct or not. my thinking was the foam would act as a moisture "deterrent", keeping any moisture away from the carpet. however, i installed a "gasket" cut from a roll of gasket material the shape of the foam gasket, [slightly larger in fact] sealed to the floor with a thin smear of seam sealer, before the foam square, just to be absolutely sure no moisture would come through this area. i know this isn't correct by any stretch of the imagination, but that's what i did anyway. i also greased up the gas pedal studs with high temp copper anti-seize before i nailed down the pedal for the final time. i will more than likely never remove the pedal in the rest of my lifetime, but did so "just because".
[Re: fastmark]
#3272109
11/24/24 07:43 AM
11/24/24 07:43 AM
Posts: 6,520 ohio
ruderunner
ohio
In my experience, water on the floor of a vehicle is infinitely more likely to come from above the car than from underneath. As such, I try not to seal my floors watertight, let the water drain out. I've even gone as far as punching extra holes, A bodies can really use that.
Angry white pureblood male
[Re: buzz440]
#3272156
11/24/24 01:00 PM
11/24/24 01:00 PM
moparx
moparx, thanks for the reply but, in your reply did you mean to say; i put the foam between the (floor) and carpet ? because your answer says you put it between the foam and carpet.
later,BUZZ i goofed Buzz ! i should have said "between the carpet and floor".......... sorry !
[Re: buzz440]
#3272267
11/25/24 03:12 AM
11/25/24 03:12 AM
Posts: 67 Arizona
340rag
Arizona
Hi all, I'm installing my brand new carpet in my 69 "bee", now I have this big 1" thick square white foam gasket that goes around the bottom of the gas pedal ( where it bolts to the floor) question is ..... does this foam gasket go under the carpet, between the floor and carpet - or - on top of the carpet, between the pedal and carpet ?
Later, BUZZ That foam gasket actually goes under the carpet—right between the floor and the carpet. It’s there to make a nice seal and keep things smooth around where the gas pedal bolts in
[Re: 340rag]
#3272300
11/25/24 10:27 AM
11/25/24 10:27 AM
Posts: 22,017 Enjoy life today, It has an ex...
gtx6970
Later, BUZZ That foam gasket actually goes under the carpet—right between the floor and the carpet. It’s there to make a nice seal and keep things smooth around where the gas pedal bolts in Agreed, Helps hold the carpet up against the bottom of the gas pedal
Enjoy life today, It has an expiration date
