white foam square at gas pedal ? #3271973
11/23/24 11:41 AM
11/23/24 11:41 AM
montreal,quebec,canada
buzz440 Offline OP
buzz440  Offline OP
Hi all, I'm installing my brand new carpet in my 69 "bee", now I have this big 1" thick square white foam gasket that goes around the bottom of the gas pedal ( where it bolts to the floor) question is ..... does this foam gasket go under the carpet, between the floor and carpet - or - on top of the carpet, between the pedal and carpet ?
Later, BUZZ
Re: white foam square at gas pedal ? [Re: buzz440] #3271980
11/23/24 12:31 PM
11/23/24 12:31 PM
moparx Online content
moparx  Online Content
when i installed the new carpet in my 69 charger this spring, i put the foam square between the carpet and foam, correct or not.
my thinking was the foam would act as a moisture "deterrent", keeping any moisture away from the carpet.
however, i installed a "gasket" cut from a roll of gasket material the shape of the foam gasket, [slightly larger in fact] sealed to the floor with a thin smear of seam sealer, before the foam square, just to be absolutely sure no moisture would come through this area. i know this isn't correct by any stretch of the imagination, but that's what i did anyway.
i also greased up the gas pedal studs with high temp copper anti-seize before i nailed down the pedal for the final time. i will more than likely never remove the pedal in the rest of my lifetime, but did so "just because".
beer
Re: white foam square at gas pedal ? [Re: moparx] #3271996
11/23/24 01:27 PM
11/23/24 01:27 PM
buzz440 Offline OP
buzz440  Offline OP
moparx, thanks for the reply but, in your reply did you mean to say; i put the foam between the (floor) and carpet ? because your answer says you put it between the foam and carpet.
later,BUZZ
Re: white foam square at gas pedal ? [Re: buzz440] #3272054
11/23/24 08:30 PM
11/23/24 08:30 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Between floor and underside of carpet - to keep moisture from pedal studs seeping into the jute insulation.
BTW - Base of pedal should mount just inside the forward corner of the heel pad, and just inboard of the heel pad's right border.
It's tough to cut that rectangle - which should be same size of the raised portion at the pedal mounting surface.
Re: white foam square at gas pedal ? [Re: topside] #3272107
11/24/24 06:04 AM
11/24/24 06:04 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Unfortunately, you can’t just cut a hole for the gas pedal in the top right corner of the heel pad with aftermarket carpet. Most heel pads are way off from where they should be. Even on the ESC carport. You need to fit it at the hump first. Automatic floors are easier than four speeds to fit. The foam goes under the carpet.
Re: white foam square at gas pedal ? [Re: fastmark] #3272109
11/24/24 07:43 AM
11/24/24 07:43 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
In my experience, water on the floor of a vehicle is infinitely more likely to come from above the car than from underneath. As such, I try not to seal my floors watertight, let the water drain out. I've even gone as far as punching extra holes, A bodies can really use that.
Angry white pureblood male
Re: white foam square at gas pedal ? [Re: ruderunner] #3272115
11/24/24 08:35 AM
11/24/24 08:35 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
1" thick
??? Did that come in a kit?
