Page 3 of 3 1 2 3
340 T/A-AAR Cylinder heads/rockers/pushrods [Re: moparts] #3267725
11/02/24 10:11 AM
11/02/24 10:11 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
I have a set of 340 T/A heads with valves,springs,correct offset rockers,shafts and pushrods. Some rockers are stuck,sitting for 20+ years(inside) and pulled from the engine a few years ago.Good shape overall but shouild be considered as rebuilder cores.No porting done to the heads. I'll add pics soon. Edit: Most rockers spin freely on shafts,some have limited travel for some reason but are not galled on the shaft.
Located in Pittsburgh,PA 15229
Asking $3500.00 for all
PM here,E mail to RTSrunner-at-yahoo dot com,text to 412.4oo.o974; Thanks RT
Barracuda Cuda Challenger
4.03" Cast pistons fir Small Block for sale [Re: moparts] #3268099
11/04/24 04:30 PM
11/04/24 04:30 PM
Here
jcc Online content
No soup for you!!!
jcc  Online Content
No soup for you!!!
Here
No pins, new, CH approx 1.56"
8 .030 over, small dish as pictured
$60 OBO plus shipping, PM
I'm with Helmuth Hübener, and no soup is being served today.
W-9 (2) For Sale Small Block Engine [Re: moparts] #3268183
11/04/24 09:52 PM
11/04/24 09:52 PM
Here
jcc Online content
No soup for you!!!
jcc  Online Content
No soup for you!!!
Here
Never run/mounted, almost new #P5007065, as pictured
One port was deburred, port cleaned up, and valve job, reported to flow 350cfm
Heads were pressure tested, tech states there is lot more left in the heads flow wise.
$1600 pair, plus shipping, PM, delivery east of Mississippi possible for extra fee
1969 340 [Re: moparts] #3270560
11/15/24 07:34 AM
11/15/24 07:34 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
I'm looking for a late 1968/early 1969 340. Block, short block, complete, core or rebuilt. Just need one for my GTS.
Located in central Ohio.
1969 Dart GTS 340
1969 Coronet R/T X9 N-96
1999 Dodge Dakota R/T RC
2015 Dodge Dart GT
2019 Ram 2500 Big Horn
Nos stock 340 grind Camshaft [Re: OhioMopar] #3270655
11/15/24 05:07 PM
11/15/24 05:07 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Nos Perfect Circle factory stock 340 grind cam #229-1654. Lift is verified by me. Made when cores and grinding were good. Will pack well. $175 shipped lower 48. Postal money order. Pm me here
#229-1654........ .429"/.444' ~ 268*/276* ~ 114* CL
Mopar Electronic Distrbutor [Re: moparts] #3270977
11/17/24 06:23 PM
11/17/24 06:23 PM
Chicago area
Magnum GT Offline
Magnum GT  Offline
Chicago area
Small block distributor, used, #3690430. $80 plus shipping.
Steve - magnumracing@sbcglobal.net
dstb 1.jpg (199 downloads)
dstb 2.jpg (200 downloads)
dstb 3.jpg (200 downloads)
Steve
1979 Magnum GT
Wanted, Poly 318 Valve Cover [Re: moparts] #3271033
11/18/24 07:25 AM
11/18/24 07:25 AM
E
earlymopar Offline
earlymopar  Offline
E
I'm looking for a single Poly 318 valve cover to cut up for use as a tool to view oil transfer on a running engine. Condition doesn't need to be perfect.
Please PM me here if you have anything. I'm located in NW Oregon.
340 AIR CLEANER [Re: earlymopar] #3271968
11/23/24 11:08 AM
11/23/24 11:08 AM
Western,NY
JEJJ Offline
JEJJ  Offline
Western,NY
NICE 340 AIR CLEANER....$175
THANK YOU
716-997-0070
BAKURRUDA@AOL.COM
1969 sb timing cover [Re: Hot 340] #3272065
11/23/24 09:02 PM
11/23/24 09:02 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
1969 dated timing cover. $115 shipped Lower 48. Postal money order only. Pm me here.
Page 3 of 3 1 2 3
