white foam square at gas pedal ? #3271973
11/23/24 11:41 AM
11/23/24 11:41 AM
montreal,quebec,canada
buzz440 Offline OP
buzz440  Offline OP
Hi all, I'm installing my brand new carpet in my 69 "bee", now I have this big 1" thick square white foam gasket that goes around the bottom of the gas pedal ( where it bolts to the floor) question is ..... does this foam gasket go under the carpet, between the floor and carpet - or - on top of the carpet, between the pedal and carpet ?
Later, BUZZ
Re: white foam square at gas pedal ? [Re: buzz440] #3271980
11/23/24 12:31 PM
11/23/24 12:31 PM
moparx Offline
moparx  Offline
when i installed the new carpet in my 69 charger this spring, i put the foam square between the carpet and foam, correct or not.
my thinking was the foam would act as a moisture "deterrent", keeping any moisture away from the carpet.
however, i installed a "gasket" cut from a roll of gasket material the shape of the foam gasket, [slightly larger in fact] sealed to the floor with a thin smear of seam sealer, before the foam square, just to be absolutely sure no moisture would come through this area. i know this isn't correct by any stretch of the imagination, but that's what i did anyway.
i also greased up the gas pedal studs with high temp copper anti-seize before i nailed down the pedal for the final time. i will more than likely never remove the pedal in the rest of my lifetime, but did so "just because".
beer
Re: white foam square at gas pedal ? [Re: moparx] #3271996
11/23/24 01:27 PM
11/23/24 01:27 PM
buzz440 Offline OP
buzz440  Offline OP
moparx, thanks for the reply but, in your reply did you mean to say; i put the foam between the (floor) and carpet ? because your answer says you put it between the foam and carpet.
later,BUZZ
Re: white foam square at gas pedal ? [Re: buzz440] #3272054
11/23/24 08:30 PM
11/23/24 08:30 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Between floor and underside of carpet - to keep moisture from pedal studs seeping into the jute insulation.
BTW - Base of pedal should mount just inside the forward corner of the heel pad, and just inboard of the heel pad's right border.
It's tough to cut that rectangle - which should be same size of the raised portion at the pedal mounting surface.
