68 Dart convertible. These trim clips go around the back of the body to hold on the stainless trim. Most of the clips fit nice but a few of them do not. There are a few places where the metal is double thick and the clip doesn't want to sit down all the way. Also, the extra thickness makes the clip stick out on the inside at the bottom. I'm not certain, but wouldn't the convertible top rub on the sharp bottom edge of the clip if it sticks out and doesn't sit flush with the body? I was thinking of taking a belt sander to the inside piece of metal to knock down the lip and thickness a bit. Good idea or not? These are the original trim clips and no body work/ metal replacement was done in this area so it must have done the same thing from the factory. Thanks
