D150 Power window motor??? #3270980
11/17/24 06:44 PM
11/17/24 06:44 PM
mn
flyman Offline OP
flyman  Offline OP
mn
Lots of options on window motor replacements Any real world experience. What ones to avoid or use Thanks in advance
Re: D150 Power window motor??? [Re: flyman] #3270998
11/17/24 09:47 PM
11/17/24 09:47 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
popcorn
I will be watching as well.
My Monster are real!
Living within your means makes life pretty easy.
Re: D150 Power window motor??? [Re: flyman] #3271013
11/17/24 10:52 PM
11/17/24 10:52 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
Is your motor kaput or are the plastic gears stripped out? work
Re: D150 Power window motor??? [Re: Hugh Jorgan] #3271165
11/18/24 08:32 PM
11/18/24 08:32 PM
mn
flyman Offline OP
flyman  Offline OP
mn
It seams the motors have no power. I need to help the windows up to get closed. Im guessing the armature is coroded or just worn out??
Re: D150 Power window motor??? [Re: flyman] #3271168
11/18/24 08:38 PM
11/18/24 08:38 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
Brushes.
Re: D150 Power window motor??? [Re: Hugh Jorgan] #3271540
11/20/24 07:01 PM
11/20/24 07:01 PM
mn
flyman Offline OP
flyman  Offline OP
mn
I guess Im not sure if you are saying I should replace the brushes or correcting my troubleshooting?? Either could be corouded?
