D150 Power window motor??? #3270980
11/17/24 06:44 PM
11/17/24 06:44 PM
mn
flyman Offline OP
flyman  Offline OP
mn
Lots of options on window motor replacements Any real world experience. What ones to avoid or use Thanks in advance
Re: D150 Power window motor??? [Re: flyman] #3270998
11/17/24 09:47 PM
11/17/24 09:47 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
popcorn
I will be watching as well.
My Monster are real!
Living within your means makes life pretty easy.
Re: D150 Power window motor??? [Re: flyman] #3271013
11/17/24 10:52 PM
11/17/24 10:52 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
Is your motor kaput or are the plastic gears stripped out? work
Re: D150 Power window motor??? [Re: Hugh Jorgan] #3271165
11/18/24 08:32 PM
11/18/24 08:32 PM
mn
flyman Offline OP
flyman  Offline OP
mn
It seams the motors have no power. I need to help the windows up to get closed. Im guessing the armature is coroded or just worn out??
Re: D150 Power window motor??? [Re: flyman] #3271168
11/18/24 08:38 PM
11/18/24 08:38 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
Brushes.
Re: D150 Power window motor??? [Re: Hugh Jorgan] #3271540
11/20/24 07:01 PM
11/20/24 07:01 PM
mn
flyman Offline OP
flyman  Offline OP
mn
I guess Im not sure if you are saying I should replace the brushes or correcting my troubleshooting?? Either could be corouded?
Re: D150 Power window motor??? [Re: flyman] #3271630
11/21/24 08:56 AM
11/21/24 08:56 AM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
The brushes inside the motors wear down. Replace the brushes and scotchbrite the armature's surface. Re-assemble and bench test the motor. Check the plastic gears in the transmission (top part) for wear and replace while you have it out of the truck. twocents
Re: D150 Power window motor??? [Re: Hugh Jorgan] #3271673
11/21/24 12:32 PM
11/21/24 12:32 PM
5thAve Online content
5thAve  Online Content
Make sure the grease on the track hasn't turned to sticky or hard goop too. That and those rollers in the motor gear are the biggest issues with those power windows.
