For sale are NOS brushed trim rings for the 1969 only road wheels ( 4 clip ) that I have finally decided I will not be using , so they are being put out there for sale and will also include 4 of the 1969 only 14'' x 5 1/2'' road wheels they belong with / on . These are very hard to find used never mind NOS . In all my years into Mopar , I Have never seen another set . I have gone back and forth all summer about letting these go , and concluded I will not ever use them , so someone doing an OE Daytona ( or whatever you have that uses these ) , these would be for you . 3 are still with the original paper package , one is not . 2 original part number cards as well . One of them which without doubt is and has been with this set the entire time , is still NOS and has never been on a car , but has had a small ding taken out and therefore was re polished / brushed so has a slight different hue to it vs the other 3 never touched ones . Can it have some deeper brushed marks put into to resemble the untouched ones ? I didn't attempt , as you can see now because they are right next to each other , but once on the car farther away might be not noticeable . Because of what I feel the value of these are , I will over describe them for you as if I was buying them . When I say small flaw , one has a small "pin" mark ( see pic ) , and one other has a small , small imperfection right next to a valve stem ( see pic ) . Because of the value and rarity of these , I will not ship them . $4300 , $4000 for just the trim rings .Thank you for the ad .
Berlin, CT
