Power Brake Booster Check Valve Vacuum Fitting I.D. #3270345
11/13/24 08:42 PM
11/13/24 08:42 PM
N.W. INDIANA
moparjohn Offline OP
N.W. INDIANA
I have been going through my shelf of old parts and came across this power brake booster check valve vacuum fitting.
In searching online it looks like a 3420128 for a Bendix booster for 70 & 71 HEMI cars?
I have attached some pictures and the last one is a close up of the logo.
I would like to know if this is an original factory part?
Thanks!
Re: Power Brake Booster Check Valve Vacuum Fitting I.D. [Re: moparjohn] #3270429
11/14/24 10:55 AM
11/14/24 10:55 AM
moparx Offline
moparx  Offline
having kept many of those check valves over the years "just because", after looking for them, they must be in a "safe place", because i can't find them ! [gee, imagine that ! laugh2]
however, after saying that, your valve looks like some i have pulled from mid to late 70's C-body's.
unfortunately, as i can't find my stash of those valves, i can not confirm the cast in lettering as being a factory part.
so just consider this as a bump, so others with more brains than i possess can confirm or not your part is a factory item.
beer
Re: Power Brake Booster Check Valve Vacuum Fitting I.D. [Re: moparx] #3277009
12/18/24 10:31 PM
12/18/24 10:31 PM
N.W. INDIANA
N.W. INDIANA
moparx,
Thanks for the bump!
I have decided because of the lack of responses I will put the check valve back on the spare parts shelf.
The next time I go to a high level show with HEMI cars in attendance I will bring it along and see what I find on them?
MJ
