Re: '14 JKU M-380 - "Kilroy"
[Re: Fat_Mike]
#3277740
12/23/24 11:27 AM
12/23/24 11:27 AM
Posts: 314 Falcon, CO
Mad-Max
Falcon, CO
71 Demon (project): 318, A-833od, 8-3/4, 3.23's 14 Wrangler JKU M-380 "Kilroy" (under construction): Magnum 360, 46rh, Atlas4, D60/14b-5.38s-Grizzlys, 40s 52 Willys M-38 "Poncho"
[Re: BDW]
#3278833
12/29/24 01:28 PM
12/29/24 01:28 PM
Mad-Max
Falcon, CO
[Re: Mad-Max]
#3279073
12/30/24 01:13 PM
12/30/24 01:13 PM
Mad-Max
Falcon, CO
[Re: Mad-Max]
#3279311
12/31/24 12:03 PM
12/31/24 12:03 PM
Mad-Max
Falcon, CO
[Re: Mad-Max]
#3280208
01/03/25 12:34 PM
01/03/25 12:34 PM
Mad-Max
Falcon, CO
[Re: Mad-Max]
#3282441
01/13/25 10:22 AM
01/13/25 10:22 AM
Mad-Max
Falcon, CO
the inner fenders need some support along the inside edge, and I'll eventually have fender liners to protect the engine and such from splash and debris, so I made the center section of the fender liners which serve as support for the inner fenders - makes everything good n strong especially the p-side to support the 65lb battery - should work great. I'll complete the fender liners after it's running... bolts to the shock tower - and to the inner fenders - and sitting on a megaware battery guard (gel mat) the battery mounts are essentially done - like everything else ready for final welding and paint -
[Re: BDW]
#3282617
01/14/25 10:53 AM
01/14/25 10:53 AM
Mad-Max
Falcon, CO
I think they will have better 'retaining power' than the typical nutzerts, but potentially less 'counter-rotating' power - meaning they might spin if over-cranked etc., so I am planning to tack weld the sides of every one of them for good measure. The tool I have is just the typical nutzert tool, which I had to modify the chuck to let it thread deeper into the longer rivet nuts for more thread capture
[Re: Mad-Max]
#3283585
01/19/25 11:50 AM
01/19/25 11:50 AM
Mad-Max
Falcon, CO
ok - 2.5" front frame chop done, trimmed the front bumper to get it and the winch as close to the grille as possible (without modifying the grille) - chopped out the crash bar, and welded in a mount for the 20" 8an (1/2") dual-pass power steering cooler - shouldn't put very much 'heat' into the radiator...which was my primary concern - and finally got to pull the trigger on a fun mod - since I'm doing open cowl surgery anyway (to swap the RHD wipers and linkage to LHD)...well there's an excellent spot right there just beggin' to be used for better things, so I'm putting my air intake in there, way up high and as cool as reasonably possible - it'll have a short/stubby M-35 style snorkel built into the cover panel - should work great. The intake tube will be welded into the firewall, and with polyurethane engine mounts there shouldn't be much wiggle placed on it, and the silicone coupler will absorb any leftovers - [img] https://i.imgur.com/K9T8qxs.jpg[/img] and with the power steering cooler in place I think I may actually have all of the critical systems mapped out...and after a very thorough (and long overdue) shop cleanup I'll pull the body back off for the firewall and other final mods, and...I think...I'll be ready to slap on some Rustoleum Rusty Metal Primer and Air Force Blue on the engine pay panels...and then (gasp) be ready to assemble this thing for reals.
[Re: Mad-Max]
#3283735
01/20/25 11:32 AM
01/20/25 11:32 AM
Mad-Max
Falcon, CO
...it's been a year since I started wrenchin' on the Jeep...and I'm happy to say it's going great and I'm staying motivated. The first stage was 'figuring things out' and just getting enough hardware in place (like figuring out how to make all the driveline fit, etc). Stage two was getting things to actually connect to each other (t-case linkage, pedals, reservoirs, panels/brackets, etc), and now the final stage is getting things wet, laying in the wiring, and getting it running/driving. As I'm getting ready to make the final push I first need to clean my room...and this morning I actually found the surface of my workbench!...
