Re: point me in the right direction on an engine build.
[Re: chrisf]
#3269657
11/10/24 04:28 PM
11/10/24 04:28 PM
Posts: 12,492 Kalispell Mt.
HotRodDave
Kalispell Mt.
An eagle head swap, 6.1 cam, and long tube headers will easily get you into that range. You don't even need to touch the bottom end for that little HP. This is hands down the best bang for the buck to get you to that power level.
Don't be afraid of the compression gained from that swap with stock head gaskets, they run fine on 91 octane. This is not an iron headed, iron intake, oil heated intake, coolant heated intake, crappy open chamber, iron headed, 1960s design that detonates at 10 to 1 compression, they are totally fine with 12 to1.
[Re: HotRodDave]
#3269758
11/11/24 02:07 AM
11/11/24 02:07 AM
Posts: 4,280 Canada
WO23Coronet
Canada
You've ran Eagle headed early 5.7's without the thick head gaskets on pump 91? I have an early 5.7 to go in a swap, and I have a set of Eagles (and Apaches) and was considering using them but didn't want to go with the thicker head gaskets, pushrods etc. I have a 6.1 cam and 6.1 Jeep SRT manifolds for exhaust. Will be using the A518 with a 2500 stall and 4.56 gear
[Re: WO23Coronet]
#3269954
11/11/24 09:55 PM
11/11/24 09:55 PM
HotRodDave
Kalispell Mt.
Yes and the only time it ever showed any activity on the knock sensors was with 87 octane and even then it wasn't much.
[Re: WO23Coronet]
#3270095
11/12/24 05:58 PM
11/12/24 05:58 PM
Posts: 5,975 British Columbia
chrisf
British Columbia
appreciate the replies guys
so my thoughts as of today. 2006 5.7 block. 4" stroker. stock eagle heads (65cc), 10.5-11-1 compression 6.1 intake, headers and ill figure out the cam when the time comes. so what headers do i use? 09-up?
sound like a ok plan?
