1975 D-700 Wheel Cylinder #3269582
11/10/24 11:08 AM
11/10/24 11:08 AM
McGregor,Iowa 52157
500ciDuster Offline OP
McGregor,Iowa 52157
I have a 1975 D-700 that needs both rear wheel cylinders replaced and am having trouble finding the part number, it takes 2 per side. If I can't find the wheel cylinders, I will probably just rebuild my old ones
Re: 1975 D-700 Wheel Cylinder [Re: 500ciDuster] #3269586
11/10/24 11:26 AM
11/10/24 11:26 AM
McGregor,Iowa 52157
McGregor,Iowa 52157
I did see this number that was sold in pairs pop up a couple times EW771206
Re: 1975 D-700 Wheel Cylinder [Re: 500ciDuster] #3269709
11/10/24 07:38 PM
11/10/24 07:38 PM
Central Michigan
N
nuthinbutmopar Offline
N
Central Michigan
Usually easiest just to get the diameter and rebuild them.
Re: 1975 D-700 Wheel Cylinder [Re: nuthinbutmopar] #3269768
11/11/24 06:25 AM
11/11/24 06:25 AM
McGregor,Iowa 52157
McGregor,Iowa 52157
Yes, have done that before. They have 1 5/8" piston and was hoping I could just find the number because the parts stores can't even get me one. WC24489 looks like it might be it
Re: 1975 D-700 Wheel Cylinder [Re: 500ciDuster] #3270167
11/13/24 07:05 AM
11/13/24 07:05 AM
McGregor,Iowa 52157
McGregor,Iowa 52157
The WC24489 was the exact part, $25.99 each at O'reilly's w/no core. Looks like chiivy, phord and intersmashible use the same wheel cylinder since they probably use the same two speed rear axle.
