Any tutorials out there on converting a Group 27 to a AGM ? #3269020
11/07/24 11:04 PM
11/07/24 11:04 PM
God's Country - Etowah, TN.
A34 Offline OP
A34  Offline OP
Hey Guys,
I have an old Group 27 that I'd like to convert to a modern AGM battery. Any tutorials out there on how to do it, what parts to buy, etc?
Thanks!
God Bless America, Our Troops and Their Families !
DEO VINDICE
Re: Any tutorials out there on converting a Group 27 to a AGM ? [Re: A34] #3269069
11/08/24 09:23 AM
11/08/24 09:23 AM
KY
65pacecar Offline
65pacecar  Offline
KY
Re: Any tutorials out there on converting a Group 27 to a AGM ? [Re: 65pacecar] #3269129
11/08/24 01:10 PM
11/08/24 01:10 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Messy job for sure - I did this to my battery in the RR about 7-8 years ago and cranks over the Hemi with no problems. I tapped the bottom of the posts to secure the terminal lugs but also like the idea of creating the copper sleeves to gain the better fit for standard battery connections.
Re: Any tutorials out there on converting a Group 27 to a AGM ? [Re: 65pacecar] #3269243
11/08/24 09:44 PM
11/08/24 09:44 PM
A34 Offline OP
A34  Offline OP
Originally Posted by 65pacecar
Thanks! I'll check it out!
DEO VINDICE
Re: Any tutorials out there on converting a Group 27 to a AGM ? [Re: 68jim] #3269244
11/08/24 09:45 PM
11/08/24 09:45 PM
A34 Offline OP
A34  Offline OP
Good idea!
DEO VINDICE
Re: Any tutorials out there on converting a Group 27 to a AGM ? [Re: A34] #3269257
11/08/24 11:26 PM
11/08/24 11:26 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have converted/gutted 3 of my batteries all with great results. As the above link showed. Here is mine.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Any tutorials out there on converting a Group 27 to a AGM ? [Re: 6PKRTSE] #3269550
11/10/24 08:02 AM
11/10/24 08:02 AM
KY
65pacecar Offline
65pacecar  Offline
KY
Does anyone sell an empty case to save on the messy cleanup process?
Re: Any tutorials out there on converting a Group 27 to a AGM ? [Re: 65pacecar] #3269606
11/10/24 12:13 PM
11/10/24 12:13 PM
moparx Offline
Buying your homeless and unwanted bolt on battery terminals
moparx  Offline
i can't answer that question, but maybe a "topper" would work for you ? shruggy
that is, if they are made in a "quality" model anymore..............
just tossing this out there, as i have no experience with these things.
beer
Re: Any tutorials out there on converting a Group 27 to a AGM ? [Re: A34] #3269641
11/10/24 02:34 PM
11/10/24 02:34 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Originally Posted by A34
Hey Guys,
Thanks!
Do you me convert to a lithium-ion battery and not an AGM battery? AGM is a semi "wet" or flooded battery with an absorbent material between the plates that doesn't leak or spill for the most part as the glass mat maintains the acid inside the battery, Group 27 (and group 24) AGM OE copy batteries have been around for a while (hard to find lately shruggy ) if that's what you're looking for but I think you're for a basically dry and light weight lithium-ion battery or a way to convert an old failed AGM battery case by putting a smaller lithium-ion battery inside. Is this the plan? AGM = Absorbent Glass Mat
Re: Any tutorials out there on converting a Group 27 to a AGM ? [Re: A12] #3269746
11/10/24 10:26 PM
11/10/24 10:26 PM
A34 Offline OP
A34  Offline OP
Hey Guys,
Thanks!
I did not think of a lithium-ion battery, but I suppose that would definitely be better. What I have is a failed repro battery, that is probably a lead-acid one and not AGM. Are you aware of any lithium ones that would do the trick here? Thanks!
DEO VINDICE
Re: Any tutorials out there on converting a Group 27 to a AGM ? [Re: A34] #3277548
12/22/24 01:19 AM
12/22/24 01:19 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I use the Antigravity ATX20-HD. It weighs 5 lb and spins my 13 to 1 Hemi over like the plugs are out of it.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Any tutorials out there on converting a Group 27 to a AGM ? [Re: Hemi_Joel] #3277577
12/22/24 09:17 AM
12/22/24 09:17 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
I just cut the bottom out of mine to discover this. I could see cables and a smaller battery when I unscrewed the red caps.PC950
The one before was an AGM and it was messy but I drilled pilot holes into the bottom of the posts and used small lag bolts to attach the cables.
1969 Hemi Roadrunner 2nd owner
Re: Any tutorials out there on converting a Group 27 to a AGM ? [Re: 69hemibeep] #3277599
12/22/24 11:43 AM
12/22/24 11:43 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I don't under understand how your cables are connected to the old battery inside. Can you please clarify?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Any tutorials out there on converting a Group 27 to a AGM ? [Re: Hemi_Joel] #3277714
12/23/24 08:14 AM
12/23/24 08:14 AM
MN
Droop69 Offline
Droop69  Offline
MN
This battery lists for as much as the reproduction. $300.00 to $400.00.
Re: Any tutorials out there on converting a Group 27 to a AGM ? [Re: Hemi_Joel] #3277715
12/23/24 08:21 AM
12/23/24 08:21 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
The one pictured, the cables were poured into the lead posts by the original manufacturer. The one I did years ago was an AGM that I gutted and drilled the bottom of the post and lag bolted cables to. I can get a picture of it if you like!
Re: Any tutorials out there on converting a Group 27 to a AGM ? [Re: 69hemibeep] #3277773
12/23/24 03:17 PM
12/23/24 03:17 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
Napa Proformer battery (24C-6) with topper and mopar script added.
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: Any tutorials out there on converting a Group 27 to a AGM ? [Re: RealWing] #3278742
12/28/24 08:13 PM
12/28/24 08:13 PM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
I have done this a couple of times with repro batteries. Picked up an appropriately sized AGM battery from Battery Mart, cut the top off the reproduction battery box at the seam with a dremel and swapped out the guts. ‘Glued” the box back together with black RTV.
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
Re: Any tutorials out there on converting a Group 27 to a AGM ? [Re: Hemi_Joel] #3278756
12/29/24 12:30 AM
12/29/24 12:30 AM
WA
tman Offline
tman  Offline
WA
I purchased my g27 red cap repro batt from BatteryCentralMall in 2021. The repro batteries are built this way. When I remove a cap, you can see a smaller battery inside just like the photo. At least when this battery fails on me, I can just remove the bottom or top and put in a replacement w/o having to gut an old wet or agm type battery.
Re: Any tutorials out there on converting a Group 27 to a AGM ? [Re: tman] #3279344
12/31/24 02:47 PM
12/31/24 02:47 PM
A34 Offline OP
A34  Offline OP
Lots of good info, thanks guys!!
DEO VINDICE
