Opinions on Hemi rods #3266753
10/27/24 08:59 PM
10/27/24 08:59 PM
fredericksburg,va
cudaman1969 Offline OP
Itch Nutz
Itch Nutz
fredericksburg,va
I’m looking at the h beam rod for my Hemi, Scat, K1 or Molinar. Close in price $650 to $750. Just a street engine and I don’t want the stock rod (heavy, 1050 vs 850 grams). Ross pistons and 4.150 crank.
Opinions?
Re: Opinions on Hemi rods [Re: cudaman1969] #3266758
10/27/24 09:11 PM
10/27/24 09:11 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
I have Scat with arp 2000 bolts. 6.860 length. They work. Molar might be lighter.
Best deal in town -link below. (Not arp 2000 bolts)
https://cnc-motorsports.com/2-426-6860-2374-1030-scat-chrysler-426-hemi-connecting-rods-h-beam.html
Re: Opinions on Hemi rods [Re: Hot 340] #3266763
10/27/24 09:34 PM
10/27/24 09:34 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The Molnar .990/2.200/7.100 is a very nice rod for the money. They weigh 838 grams. I run them in my wedge race motor. 4.500” stroke regularly to 7100-7200. ARP 2000 bolts are standard.
Doug
Re: Opinions on Hemi rods [Re: dvw] #3266767
10/27/24 09:46 PM
10/27/24 09:46 PM
fredericksburg,va
Itch Nutz
Itch Nutz
fredericksburg,va
have the 1.03 pin and standard big end. I have a set of ARP 2000 bolts, are they interchangeable?
Re: Opinions on Hemi rods [Re: cudaman1969] #3266783
10/27/24 11:24 PM
10/27/24 11:24 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
I figured your 4.150 stroke pistons would be for 7.1" rods with .990 pins.
2011 Drag Pak Challenger
Re: Opinions on Hemi rods [Re: rickseeman] #3266784
10/27/24 11:26 PM
10/27/24 11:26 PM
Stuttgart, Arkansas
Stuttgart, Arkansas
Whose crank are you using? Some stroker cranks are for Mopar width rods and some are for Chevy width rods.
Re: Opinions on Hemi rods [Re: dvw] #3266812
10/28/24 08:08 AM
10/28/24 08:08 AM
gregsdart Online content
gregsdart  Online Content
Doug
i run the same rod, 4.315 stroke, spin mine to 7800, has seen 8,000 multiple times due to issues with setup.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: Opinions on Hemi rods [Re: cudaman1969] #3266818
10/28/24 08:43 AM
10/28/24 08:43 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
I wouldn't be scared to run any of those brands, but I'd probably go w/ Molnar if I had the choice. up
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Re: Opinions on Hemi rods [Re: rickseeman] #3266823
10/28/24 09:35 AM
10/28/24 09:35 AM
fredericksburg,va
Itch Nutz
Itch Nutz
fredericksburg,va
Pistons were made for a 426 Super Stock engine (stock sizes in1997) with 10.44 deck. So with the 4.150 crank they will still be down in hole .090 (block is cut .060 now) cutting compression some. $250 is better than $2200 for new pistons don’t ya think?
The stock rods I have are new so maybe ill put them up for sale to offset the cost or use them in the other block I have to sell.
Re: Opinions on Hemi rods [Re: an8sec70cuda] #3266824
10/28/24 09:40 AM
10/28/24 09:40 AM
fredericksburg,va
Itch Nutz
Itch Nutz
fredericksburg,va
Which ever set I buy I want to do no extra work on them, more cost.
Thanks for reply on t-plate
Re: Opinions on Hemi rods [Re: gregsdart] #3266873
10/28/24 01:39 PM
10/28/24 01:39 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Doug
Same rods here with A 4.250 stroke shifting at 7600.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Opinions on Hemi rods [Re: cudaman1969] #3266989
10/28/24 11:35 PM
10/28/24 11:35 PM
NY
B1duster Offline
B1duster  Offline
NY
Don’t know what bore your block is but you might want to reconsider using those pistons and use something like this.
Re: Opinions on Hemi rods [Re: cudaman1969] #3267003
10/29/24 07:25 AM
10/29/24 07:25 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I bought 6.86-1.030 dimension Scat rods, I believe they have the standard ARP bolts same as linked to above, for a standard stroke, nearly stock 426ci 'drive it anywhere, anytime' type of future project currently stuck in the planning/collecting stages.
That engine would be fine with stock rods, but I don't have any. Must have been 14 years ago and they were only $350 as an open box item. They still seem to be a good value in the link.
I bought Molnar 2.200-7.100 for my 572.
(Not helpful: The 572 has ran a total of about 15 minutes on the garage floor and has seen nearly 4000 rpm a few times, and the connecting rods performed flawlessly laugh2)
Campbell Enterprises is advertising Molnar for $666 right now. Not positive but I think that might be the best price.
I have purchased cranks and rods from Campbell before, they were good.
The Molnar are a nicer product and I feel they are worth more than the $83 per rod that they currently cost.
The Scat in the above link are priced right and are also a very good value.
Don't know about K1, I have used one of their crankshafts but not their rods.
Rich H.
Esse Quam Videri
Re: Opinions on Hemi rods [Re: ZIPPY] #3267028
10/29/24 09:21 AM
10/29/24 09:21 AM
Apollo, PA.
B1MAXX Online content
B1MAXX  Online Content
Apollo, PA.
My personal stuff has scat 8740's. Most I ever turned was 7400-7500 (5.13's) in a wedge application. I always considered them a step up into the good stuff and have never broken a rod. But I come from a time when bushed re bolted LY's were the hot ticket.
Re: Opinions on Hemi rods [Re: B1duster] #3267210
10/30/24 11:06 AM
10/30/24 11:06 AM
fredericksburg,va
Itch Nutz
Itch Nutz
fredericksburg,va
These are the pistons I have now, why buy more
Re: Opinions on Hemi rods [Re: cudaman1969] #3267233
10/30/24 12:25 PM
10/30/24 12:25 PM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
Opinions?
I run K1 rods in my Hemis and they have been great so far and measured well out of the box. I don't think K1 makes gen 2 hemi rods anymore. They make stroker cranks for the hemi, but I think they stopped making rods for the gen 2 hemi a while ago. You may want to consider Eagle rods as well in that price range. They're comparable to Scat stuff.
