Trying to check the rear wheel bearings for noise on my son's 2014 Charger. It has Autopark which seemed pretty cool at first.
Open the door it goes into park. Car rolls it goes into park. Car not running, it goes into park.
Basically if you aren't driving it goes into park. Kinda neat because in a moment of forgetfulness the car won't roll away on you.
BUT
You can't put the car in neutral and spin the rear wheels to see how the bearings sound unless you jack up both sides and let the differential freewheel.
Anybody know a way to disable it for a few minutes?
Tried turning traction control off. In accessory mode it goes into park. In run mode but not started, it goes into park. Even with engine running if you let off the brake it goes into park.
Not so neat now. LOL
I did find the Emergency Neutral Lever but I was thinking there would be an electronic override.
