Windshield Installation, Have You Tried It? #3266015
10/23/24 12:49 PM
10/23/24 12:49 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Getting ready to tackle the cowl rust in the '62 Dart 440. I plan on taking the upper cowl out by drilling out the spot welds to I can get to the lower cowl. I'll need to take out the windshield out to do that.
I've put rear windows/windshields in with butyl tape but I've never installed a windshield with a gasket. With a helper, some soapy water and some Hobo Freight plastic spoons will I be able to install this thing (I have medium-low patience)?
Re: Windshield Installation, Have You Tried It? [Re: VITC_GTX] #3266022
10/23/24 01:08 PM
10/23/24 01:08 PM
Enjoy life today, It has an ex...
gtx6970 Offline
gtx6970  Offline
Reinstalling the OEM glass and seal ? - Easy peasy
Enjoy life today, It has an expiration date
Re: Windshield Installation, Have You Tried It? [Re: gtx6970] #3266032
10/23/24 01:34 PM
10/23/24 01:34 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
As long as the seal is still soft and pliable. If its hard and brittle like a lot of old seals are, easy is deffenately not the correct descriptive word for the installation.
Re: Windshield Installation, Have You Tried It? [Re: poorboy] #3266033
10/23/24 01:36 PM
10/23/24 01:36 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I'll buy a new seal, I'll have to cut the old hard, crusty one out of the car when I remove the windshield.
Re: Windshield Installation, Have You Tried It? [Re: poorboy] #3266039
10/23/24 01:56 PM
10/23/24 01:56 PM
gtx6970 Offline
gtx6970  Offline
Agreed, Condition is everything
Re: Windshield Installation, Have You Tried It? [Re: poorboy] #3266043
10/23/24 02:17 PM
10/23/24 02:17 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
[quote=VITC_GTX]Getting ready to tackle the cowl rust in the '62 Dart 440. I plan on taking the upper cowl out by drilling out the spot welds to I can get to the lower cowl. I'll need to take out the windshield out to do that.
I
I had a glass company install with a new seal on my Roadrunner..... it took them 2 hours...and they were not happy..... lol
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Windshield Installation, Have You Tried It? [Re: JMCFAN] #3266064
10/23/24 04:32 PM
10/23/24 04:32 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I
I have a 49 Dodge pickup with the rear cab corner windows. I bought 2 new corner windows and two new rubber gaskets from the same company, and had them installed by a professional glass installer. The 1st attempt the guy spent 4 hours busting his butt fighting with it. He came back a few days later and we finally got them in, and sealed after another 4 hours. With my insistence, we finally had to make a couple cuts on the new rubber (on each window) to get it to go around the corners. Eight hours +, most of it for two 15" x15" corner windows, the rear center glass and both pieces of front glass only took about 45 minutes of that time. For the record, that was the only rubber gasket maker offering the rubber gaskets for corner window glass.
When the rubber doesn't fit, the install is a nightmare.
My son has a 57 Dodge wagon. It needs a new windshield (plenty OEM versions are available) but the only company that offers the rubber tells you it doesn't fit well. That company recommends you locate a car with a good pliable rubber gasket! His windshield doesn't leak, and the rubber on his 67 year old car is still soft, but he is concerned about it leaking with the new glass. The glass installer he will need to use is the same guy that installed the corner windows on my 49.
Picture of the one of new corner windows and the center rear glass, and a picture of the two piece windshield.
Re: Windshield Installation, Have You Tried It? [Re: JMCFAN] #3266086
10/23/24 06:16 PM
10/23/24 06:16 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I
That sounds a little scary eek
Re: Windshield Installation, Have You Tried It? [Re: poorboy] #3266088
10/23/24 06:20 PM
10/23/24 06:20 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I
I plan on buying the gasket from Detroit Muscle Technologies. I think they are a sponsor here on Moparts. I hope the gasket fits and works well!!
Re: Windshield Installation, Have You Tried It? [Re: VITC_GTX] #3266428
10/25/24 07:14 PM
10/25/24 07:14 PM
Minn
SportF Offline
SportF  Offline
Minn
I wouldn't say its easy peasey, but you can do it with time. DO NOT ever force it. nor tap on it with your hands. Set the glass and rubber in the bottom flange and start bringing up both sides equally. As you get to the top corner it will become harder and harder to work the outer lip over the glass, with the inside of the gasket kept on the flange. Keep the gasket soap water lubed up all the way around. As you get to the top the glass may seem an inch out, but just keep going across the top and then the glass will move in on its own and the rest of the top is easy. Expect first time about 4 hours, maybe more.
Re: Windshield Installation, Have You Tried It? [Re: VITC_GTX] #3266463
10/25/24 11:00 PM
10/25/24 11:00 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I would recommend hiring it out. The hard part will be finding someone familiar with the process. They will make it look like a walk in the park. What's a new windshield cost ??? I am fortunate I have a retired guy that does it all (side windows too) and is cheap IMO. DO verify their experience as most don't have a clue. twocents beer
Re: Windshield Installation, Have You Tried It? [Re: TJP] #3266484
10/26/24 07:10 AM
10/26/24 07:10 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Patience is a key factor. If you don't have it, you will break the glass.
Even if you do have it, you're likely to break the glass on a first try.
Angry white pureblood male
Re: Windshield Installation, Have You Tried It? [Re: ruderunner] #3266505
10/26/24 12:18 PM
10/26/24 12:18 PM
gtx6970 Offline
gtx6970  Offline
Ive done a couple myself re-using tyhe OEM glass with no problems
I needed a glass for a 68 Charger a few years ago
So had the local glass company come out and install the glass they had, guy broke it in 10 minutes. I dont know the glass brand name
I had the car transported to the shop itself , They changed glass brands ( to a pinkerington I believe ) Different guy had it in the car in under an hour
Re: Windshield Installation, Have You Tried It? [Re: gtx6970] #3266514
10/26/24 01:14 PM
10/26/24 01:14 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
The above statement says it all quite clearly IMO 👍🏻🍻
Re: Windshield Installation, Have You Tried It? [Re: TJP] #3266536
10/26/24 03:02 PM
10/26/24 03:02 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Sometimes the bet tool for the job is a checkbook.
In my collision-repair & restoration career, I've likely had a thousand windshields installed, many of them with rubber seals.
Some guys were really adept, and a few - who I didn't invite back - weren't all that capable.
I know of one '65 Plymouth - I had nothing to do with it - where the guy installed the seal inside out.
Sealant on the paint, scratches, and/or leaks still p*ss me off 10 years later.
Pilkington's glass sometimes fit better than higher-priced glass, sometimes not.
Safelite was pretty good at installing leaks; the older independent guys (as in so many other fields) were generally the best.
Re: Windshield Installation, Have You Tried It? [Re: topside] #3266550
10/26/24 03:51 PM
10/26/24 03:51 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
I just had the windows installed in my '69 Barracuda fastback. The guy I had do it was very experienced with doing older cars. It took all afternoon including installing the stainless trim. It was hard work!!!! I helped a bit - especially in installing the large back window.
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: Windshield Installation, Have You Tried It? [Re: ruderunner] #3266628
10/27/24 11:33 AM
10/27/24 11:33 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
This sounds like a challenge grin
Re: Windshield Installation, Have You Tried It? [Re: VITC_GTX] #3266646
10/27/24 01:14 PM
10/27/24 01:14 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I had NEW glass from LMC installed on my '79 Power Wagon. The two guys seem to take their time and the one older guy seem to know what he was doing. They used sealant along with the factory style gasket, also from LMC. Truck leaked bad.
Some said that newer glass tends to be thinner and that may have been problem shruggy
I removed the old delaminating glass myself, and made sure the channel was super clean and rust free.
Facts are stubborn things.
Re: Windshield Installation, Have You Tried It? [Re: larrymopar360] #3266844
10/28/24 11:55 AM
10/28/24 11:55 AM
moparx Offline
moparx  Offline
how did you get the leak[s] stopped ?
beer
Re: Windshield Installation, Have You Tried It? [Re: moparx] #3266864
10/28/24 01:14 PM
10/28/24 01:14 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
Screw LMC
