B Body Dana 60, Pinion Snubber, Driveline Vibration #326644
05/23/09 09:43 PM
05/23/09 09:43 PM
Northern VA
bulletpruf Offline OP
Northern VA
Fellas -
My 68 RR (hemi, 727, Dana 60) has some driveline vibration at about 60+ mph. Wasn't happening until recently.
Lubed the u joints (I need to swap to solid u joints) today, checked u bolts for tightness. Got pulled over on the test drive (he liked the car, no ticket), but still vibrating.
Car does not have a pinion snubber. When I got underneath, I saw where it looks like the very rear of the driveshaft smacked the floorpan - must have been an extreme angle. My guess is that I tweaked the rear u joint when this happened.
My plan - drop the driveshaft, get solid Spicer u joints installed. Install a pinion snubber. Driveshaft stuff I can handle, but any ideas on a good pinion snubber? Doesn't have to be 100% correct Mopar; car is slightly modified, and it's not going to be concourse judged.
Thanks,
Scott
Please Check Out My YouTube Channel for Vintage Musclecar and Truck Rescues and Builds -- https://www.youtube.com/@THEBULLETPROOFGARAGE/videos
Re: B Body Dana 60, Pinion Snubber, Driveline Vibration [Re: bulletpruf] #326645
05/24/09 01:21 PM
05/24/09 01:21 PM
Northern VA
Northern VA
Driveshaft is out and will go to the shop Monday or Tuesday.
Any recommendations on pinion snubbers?
Thanks,
Scott
Re: B Body Dana 60, Pinion Snubber, Driveline Vibration [Re: bulletpruf] #326646
05/24/09 09:28 PM
05/24/09 09:28 PM
Northern VA
Northern VA
Feel like I'm having a one-sided conversation here, but I bought a Mopar adjustable pinion snubber from Jeg's...
Re: B Body Dana 60, Pinion Snubber, Driveline Vibration [Re: bulletpruf] #326647
05/24/09 11:02 PM
05/24/09 11:02 PM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
What rpm is the engine turning when the vibration starts and can you drive through it? Say it starts at 3500 and vibrates til 4800??? will it vibrate in neutral at the same rpm???
Re: B Body Dana 60, Pinion Snubber, Driveline Vibration [Re: mercman1] #326648
05/25/09 12:07 AM
05/25/09 12:07 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
I don't like pinion snubbers. They hinder suspension travel. If the universal joint is going that high from axle wrap it's the fault of weak leaf springs.
Is the vibration speed or rpm related?
I correct my statement. I don't like adjustable pinion snubbers. The factory one will not hinder travel.
Re: B Body Dana 60, Pinion Snubber, Driveline Vibration [Re: mercman1] #326649
05/25/09 12:09 AM
05/25/09 12:09 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
The snubber should help the pinion angle stay in a safe area if the rear springs are overcome by the weight transfer of the car. Many say no pinion snubber is needed however I am of the opinion that if you have to have soft springs to get the tires planted a pinion snubber will be very helpful in keeping the pinion angle safe. What springs are in the car now? I would def. have the drive shaft balanced by a known good shop with the new u-joints installed. That said let them put the joints in if you do not have the proper tools or experience. If this is the case as if you can watch. I've seen several shafts ruined by inexperienced, overzealous shadetree mechanics. At the age of 16 I started that list! If you have trouble getting a response shoot me a PM or I'd be hapy to share my experiences.
Re: B Body Dana 60, Pinion Snubber, Driveline Vibration [Re: mercman1] #326650
05/25/09 12:53 PM
05/25/09 12:53 PM
Northern VA
Northern VA
I didn't check to see if it was vibrating in neutral. I feel a slight vibration at lower speeds. I also feel some clunking at low speeds when turning.
Does not seem to be rpm related; seems to be more speed related. I did not try to drive through it.
Thanks,
Scott
Re: B Body Dana 60, Pinion Snubber, Driveline Vibration [Re: Magnum] #326651
05/25/09 12:54 PM
05/25/09 12:54 PM
Northern VA
Northern VA
Leaf springs are brand new, but not sure who manufactured them.
Thanks,
Scott
Re: B Body Dana 60, Pinion Snubber, Driveline Vibration [Re: Jeremiah] #326652
05/25/09 12:57 PM
05/25/09 12:57 PM
Northern VA
Northern VA
The driveshaft shop does good work and they're inexpensive, so I'll let them handle this. I need to buy a press before I mangle my own u joints.
I don't like u joints with a zerk fitting anyway, so if this doesn't fix it, at least I've got good u-joints and have hopefully ruled out the driveshaft as the source of the problem.
Thanks,
Scott
Re: B Body Dana 60, Pinion Snubber, Driveline Vibration [Re: bulletpruf] #326653
05/25/09 07:18 PM
05/25/09 07:18 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Sounds good. Make sure to check all of the trans bolts, etc. while you are under there. I had a nasty driveshaft vibarto and it shook all kinds of bolts loose and almost wrecked the bellhousing. I also suspect that is ate up the trans mount. Had a new d-shaft cut and all was good other than lots and lots of loose bolts. I learn the hard way so others don't...
Re: B Body Dana 60, Pinion Snubber, Driveline Vibration [Re: Jeremiah] #326654
05/25/09 09:14 PM
05/25/09 09:14 PM
Northern VA
Northern VA
Good point. I'll check 'em.
Thanks,
Scott
Re: B Body Dana 60, Pinion Snubber, Driveline Vibration [Re: bulletpruf] #326655
05/27/09 01:43 PM
05/27/09 01:43 PM
Northern VA
Northern VA
Driveshaft shop says the front u joint is bad. They'll replace it with a solid joint, straighten, and balance it. Should be back in the car this evening. Maybe I can take a test drive without getting pulled over this time...
Thanks,
Scott
Re: B Body Dana 60, Pinion Snubber, Driveline Vibration [Re: bulletpruf] #326656
05/27/09 01:50 PM
05/27/09 01:50 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
Cool keep us posted....subscribing
1MYTGTX
Re: B Body Dana 60, Pinion Snubber, Driveline Vibration [Re: bulletpruf] #326657
05/28/09 06:58 AM
05/28/09 06:58 AM
Northern VA
Northern VA
#@)(&$)#@Q*I$~!!!
Driveshaft went back in last night, freshly balanced, straightened, painted, new u joints front and rear. Took her for a drive and the vibration is still there. I only felt it as I was going pretty fast (maybe 60-80 mph?). Goes away when I put it in neutral. Does not appear to be rpm related; don't feel it at high rpms at lower speeds.
This is getting frustrating...
Any other thoughts? I'll check the trans bolts for tightness this weekend.
Thanks,
Scott
Re: B Body Dana 60, Pinion Snubber, Driveline Vibration [Re: bulletpruf] #326658
05/28/09 07:11 AM
05/28/09 07:11 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
What did you determine on the length?
Length should be 50.39" ctr-ctr.
Re: B Body Dana 60, Pinion Snubber, Driveline Vibration [Re: Snoopy] #326659
05/28/09 08:56 AM
05/28/09 08:56 AM
Northern VA
Northern VA
Good question. The only measurement that I took was after I removed the driveshaft - from the tranny seal to the front of the pinion yoke was 54". Gave that to the driveshaft shop and they said the length was good. I'll measure it center to center this weekend and see what I end up with.
Thanks,
Scott
Re: B Body Dana 60, Pinion Snubber, Driveline Vibration [Re: bulletpruf] #326660
05/28/09 09:50 AM
05/28/09 09:50 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Are you running a poly transmission mount, or a stock (rubber) transmission mount?
What is the angle of your transmission centerline? Up or down toward the rear?
What is the angle of your pinion centerline? Up or down toward the rear?
How much driveshaft travel before the slip yoke bottoms out inside the transmission?
Does the slip yoke fit fairly tight inside the transmsission tail bushing?
Re: B Body Dana 60, Pinion Snubber, Driveline Vibration [Re: bulletpruf] #326661
05/28/09 11:22 AM
05/28/09 11:22 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Thanks,
Scott
Why would the front joint have gone bad if the rear was what hit the floor?
Also STRAIGHTEN ??? , straighten WHAT ???
Re: B Body Dana 60, Pinion Snubber, Driveline Vibration [Re: DoctorDiff] #326662
05/28/09 04:41 PM
05/28/09 04:41 PM
Northern VA
Northern VA
Only thing that I can answer now is that the slip yoke fits fairly tight inside the tail housing. Will check the trans mount. As for the geometry questions, I'll have to check; I was under it yesterday, but the back end was way up in the air, and I didn't look to see how things were positioned in relation to each other when it was on the ground.
Will report back with details.
Thanks!
Scott
Re: B Body Dana 60, Pinion Snubber, Driveline Vibration [Re: JohnRR] #326663
05/28/09 04:45 PM
05/28/09 04:45 PM
Northern VA
Northern VA
Thanks,
Scott
Driveshaft shop said that the front joint was old, and it was bad. Probably the result of age, not rear diff rotation. Surprised that they didn't replace the joint when they built the car.
The shaft wasn't bent, but they check for straightness (and straighten it, if it's bent, I guess) when they balance it.
Thanks,
Scott
