Low Deck 440-1 Vs Tall Deck Edelbrock RPM Head #3265863
10/22/24 03:34 PM
10/22/24 03:34 PM
S.E. Michigan
cl440 Offline OP
cl440  Offline OP
S.E. Michigan
Current setup Is a low deck block with 440-1 heads. Thinking about building a 440 (493) with a Edelbrock RPM head. My headers with the current set up are close to my front bars. I know the height difference in the blocks and the different heads should come out to about the same height. What about width though? Is the exhaust port side to side wider or narrower with the low deck and the 440-1 head compared to a tall deck with the Edelbrock RPM head?
I already own a nice balanced 493 rotating assembly for a RB block. Was hoping to build something mild that we could swap in during a weekend if needed so we can keep on racing. Don't want to build it and then find out it wont fit without header mods
Re: Low Deck 440-1 Vs Tall Deck Edelbrock RPM Head [Re: cl440] #3265902
10/22/24 07:04 PM
10/22/24 07:04 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
If you're close enough you can come by and grab the 440 block i have and mock it up with the heads. You might even buy the block! Hmmm...
Re: Low Deck 440-1 Vs Tall Deck Edelbrock RPM Head [Re: cl440] #3265944
10/22/24 10:58 PM
10/22/24 10:58 PM
All the stock 440 blocks have weak main webbing down whiney They will crack, usually between cylinders #1 and3#, if you make above 650 HP and get close to max tune shruggy twocents
Your way better off building a 400 block or buy a new RB race block twocents
Re: Low Deck 440-1 Vs Tall Deck Edelbrock RPM Head [Re: Cab_Burge] #3265971
10/23/24 08:17 AM
10/23/24 08:17 AM
PA
moparacer Offline
moparacer  Offline
PA
What Cab said, and I have never been a fan of the stroker motors with small heads on them.
Unless you are using it to tow to the races.... laugh2
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 5.46-125
414 cid SB Dragster 7.65-174
Re: Low Deck 440-1 Vs Tall Deck Edelbrock RPM Head [Re: moparacer] #3265974
10/23/24 09:06 AM
10/23/24 09:06 AM
Massillon, Ohio
cudatom Online content
cudatom  Online Content
Massillon, Ohio
Really just depends on your goals. My 512 definitely falls into what I call a tractor motor. Does exactly what I wanted. Run 11.0 in a heavy vehicle. My wagon is 4200 lbs. I shift at 5400 and next yr will be its 10th season. It's been reliable and maintenance free. I'm sure I just jinxed it but I've definitely gotten my money out of it.
Ok
Re: Low Deck 440-1 Vs Tall Deck Edelbrock RPM Head [Re: Cab_Burge] #3265976
10/23/24 09:12 AM
10/23/24 09:12 AM
S.E. Michigan
cl440 Offline OP
cl440  Offline OP
S.E. Michigan
Yeah we have cracked a few (440's) in the past. Was thinking a mild build not a max build. Just something to keep us in the game incase something was to happen to the main motor. I guess I could sell the 493 rotating and get one for a low deck block. I have a spare set of 440-1 heads I could use. Then everything should be the same as far as exhaust port location. Just kicking around Ideas at this point.
Re: Low Deck 440-1 Vs Tall Deck Edelbrock RPM Head [Re: Cab_Burge] #3265979
10/23/24 09:38 AM
10/23/24 09:38 AM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Not necessarily true. Later 440's have thicker webbing than earlier versions. Combine that with a really light rotating assembly, low rpm and keeping an engine out of detonation and you can get well above that.
We're at a little over 800 crank on spray and have been creeping up for a while. Nothing more than arp studs in the bottom end.
In the end, though, you are correct in that the 400 is the better option.
'63 Dodge 330
11.19 @ 121 mph
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
Re: Low Deck 440-1 Vs Tall Deck Edelbrock RPM Head [Re: cl440] #3265980
10/23/24 09:38 AM
10/23/24 09:38 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I don't know if the numbers I have are accurate, but the numbers I was given is that a RB is 3/4" wider at the exhaust flange. And of course raised somewhat. (A trig major could verify that.) Looking at the pictures of your engine and chassis tubes, it looks like an RB would hit your chassis tubes. And I couldn't stand to mess up those pretty headers. I agree with Cab, a 400 is supposed to be better. I would stick with a low block. The grass isn't always greener. Just my opinion.
2011 Drag Pak Challenger
Re: Low Deck 440-1 Vs Tall Deck Edelbrock RPM Head [Re: GY3] #3266041
10/23/24 02:02 PM
10/23/24 02:02 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Quote
This is key, and it's detonating long before you can hear it.
Kevin
Re: Low Deck 440-1 Vs Tall Deck Edelbrock RPM Head [Re: cudatom] #3266067
10/23/24 04:37 PM
10/23/24 04:37 PM
PA
moparacer Offline
moparacer  Offline
PA
Oh they will definitely work. Especially in a heavy car. Just not optimal for anything with gear and higher rpm.
Re: Low Deck 440-1 Vs Tall Deck Edelbrock RPM Head [Re: moparacer] #3266103
10/23/24 07:25 PM
10/23/24 07:25 PM
Massillon, Ohio
Massillon, Ohio
Completely agree.
Ok
