Page 3 of 3 1 2 3
Re: Clearance oil pickup 4.5 stroke Hemi [Re: Blusmbl] #3264004
10/14/24 09:48 AM
10/14/24 09:48 AM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
Originally Posted by Blusmbl
Originally Posted by an8sec70cuda
I'd be concerned about the tube cracking. twocents
x2. I'd have no problems denting one but I wouldn't want to grind it in an area where it has the potential to crack. That's a lot of leverage from the end of the pickup to the threads for it to crack over time due to vibration.
Make a strap tied to top of a main cap to stop vibration,
Re: Clearance oil pickup 4.5 stroke Hemi [Re: mopar dave] #3264154
10/14/24 09:07 PM
10/14/24 09:07 PM
West Palm Beach, Florida
Craig J Offline
Craig J  Offline
Please keep updating this so I know what to do on mine... I am not going to use an external line so whatever solution you find will be very helpful.
I really wanted 4.5 stroke to keep the dome size down.
Re: Clearance oil pickup 4.5 stroke Hemi [Re: Craig J] #3264169
10/14/24 11:07 PM
10/14/24 11:07 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
for sure. i see about getting some pics this weekend.
Re: Clearance oil pickup 4.5 stroke Hemi [Re: mopar dave] #3265308
10/20/24 11:18 AM
10/20/24 11:18 AM
Mt Morris Michigan
Mt Morris Michigan
After clearancing the pan rail a bit for the tube, I have .055” between the tube and the rod shoulder and .040 between the adaptor and the rod. A bit more grinding on the adaptor and I’ll have it.
Re: Clearance oil pickup 4.5 stroke Hemi [Re: mopar dave] #3265449
10/20/24 10:25 PM
10/20/24 10:25 PM
Craig J Offline
Craig J  Offline
Well... it looks like my 572 just turned into a 540. But good to know before buying the rotating assy... Bummer for me, but thank you for sharing...
Re: Clearance oil pickup 4.5 stroke Hemi [Re: mopar dave] #3265460
10/21/24 12:13 AM
10/21/24 12:13 AM
Those clearances are wider than what I have race with in the past up work shruggy
Re: Clearance oil pickup 4.5 stroke Hemi [Re: Cab_Burge] #3265483
10/21/24 09:26 AM
10/21/24 09:26 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
x2
Re: Clearance oil pickup 4.5 stroke Hemi [Re: B1MAXX] #3265494
10/21/24 10:17 AM
10/21/24 10:17 AM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
Start it up and let the rod make its own clearance.
Re: Clearance oil pickup 4.5 stroke Hemi [Re: cudaman1969] #3265542
10/21/24 12:22 PM
10/21/24 12:22 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
if the rod touches that your going to have lot more than that that it going to touch. The only way its touching that at .020-.060, something is coming apart.
Re: Clearance oil pickup 4.5 stroke Hemi [Re: Craig J] #3265770
10/22/24 08:57 AM
10/22/24 08:57 AM
Mt Morris Michigan
Mt Morris Michigan
It will save you some trouble.
Re: Clearance oil pickup 4.5 stroke Hemi [Re: B1MAXX] #3265771
10/22/24 09:00 AM
10/22/24 09:00 AM
Mt Morris Michigan
Mt Morris Michigan
Yep, just a bit more grinding and a tapered tap to get the tube to screw in all the way. I think i will use a thin paper gasket under the adaptor, glued on with Indianhead . That should keep it in place. Anyone know the torque spec on the adaptor screws? Thanks to 440Jim, it will be internal oiled.
Re: Clearance oil pickup 4.5 stroke Hemi [Re: Cab_Burge] #3265774
10/22/24 09:10 AM
10/22/24 09:10 AM
Mt Morris Michigan
Mt Morris Michigan
Just what i hoped to hear cab. Thanks
Re: Clearance oil pickup 4.5 stroke Hemi [Re: mopar dave] #3266052
10/23/24 03:20 PM
10/23/24 03:20 PM
NC
440Jim Offline
440Jim  Offline
NC
From my build notes, I used Loctite on the ¼ allen head bolts (socket head cap screws) and torqued to 100 lb-in.
572 B1 org Part 5 - Build Notes [block oil pickup hole]
No more than 120 lb-in (10 lb-ft).
Page 3 of 3 1 2 3
