B/E front drums onto A body #3264421
10/16/24 07:52 AM
10/16/24 07:52 AM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
I have what I believe is a set of E/B body front spindles with drums (no idea what year) and am wondering if I can fit these onto my ‘70 Duster and what would it take
I have the spindles
Drums
Brake parts
LCA’s
Just trying to use what I have
Thanks !
Re: B/E front drums onto A body [Re: lostdog] #3264597
10/16/24 06:16 PM
10/16/24 06:16 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
I think you need 73 up upper A body arms due to different ball joints.
Bolt pattern is different too, 4.5 vs 4.0 circle.
Angry white pureblood male
Re: B/E front drums onto A body [Re: ruderunner] #3264598
10/16/24 06:28 PM
10/16/24 06:28 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
Yes. I know the ball joint and bolt pattern is different but changing to larger pattern anyway.
Re: B/E front drums onto A body [Re: lostdog] #3264648
10/17/24 03:03 AM
10/17/24 03:03 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
that will work.
like you said you need the larger UBJ and the corresponding 73-76 A-body A-arms.
The LCA's do not need to be changed.
Spring Fling 37 May 3 & 4, 2025 at Woodley Park, Van Nuys CA
600+ Mopars, 200+ swap, midway, Friday Malibu cruise,
