drive by Cable throttle body #3262478
10/07/24 11:35 AM
10/07/24 11:35 AM
K
Kiddart Offline OP
Kiddart  Offline OP
K
if anyone knows what throttle bodies direct bolt to the 6.4 intake that are drive by cable? I would greatly appreciate it
Thank you
Kiddart
Re: drive by Cable throttle body [Re: Kiddart] #3263030
10/09/24 01:12 PM
10/09/24 01:12 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
never mind im going to run the terminator X max with the drive by wire option.
Thank you
Kiddart
Re: drive by Cable throttle body [Re: Kiddart] #3263032
10/09/24 01:14 PM
10/09/24 01:14 PM
BDW Offline
BDW  Offline
What trans?
Re: drive by Cable throttle body [Re: BDW] #3263222
10/10/24 10:59 AM
10/10/24 10:59 AM
K
Kiddart Offline OP
Kiddart  Offline OP
K
727 for now
Thank you
Kiddart
Re: drive by Cable throttle body [Re: BDW] #3265345
10/20/24 02:15 PM
10/20/24 02:15 PM
Dyno1 Offline
Dyno1  Offline
I use the BBK with a LoCar cable
