Re: Front wheel bearing seal - which way ??
[Re: Neil]
#3262878
10/08/24 06:53 PM
10/08/24 06:53 PM
Posts: 9,161 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Metal facing up away from the rotor, and the interior tension spring side facing inboard down inside the rotor. Think of how a seal puller works at these from behind if you were to remove it.
If you try to install seals the other way the seal will get wrecked almost guaranteed. Just so we're clear ... photo 1 or photo 2 ??
[Re: Stanton]
#3262882
10/08/24 07:06 PM
10/08/24 07:06 PM
Posts: 21,596 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
The pictures on the right look proper with where the tension spring would normally go facing inboard towards the car. Looking at it again with that extra rubber lip hanging out there these may be a pain to install?
Never seen a wheel bearing seal made like that before. It very well may rub or bottom out once the rotor goes on the spindle depending on the depth of the bearing in the rotors and how it all fits so beware of that. If it does not work just get another more conventional seal with the same inside and outside diameters.
If you have some clay you can install one rotor without the seal and use the clay to see how much gap you have between the rotor seal surface over to the end of the spindle and then check that against how wide those seals are,
[Re: Stanton]
#3262892
10/08/24 08:02 PM
10/08/24 08:02 PM
Posts: 14 West Georgia, USA
Vaanth
West Georgia, USA
The seal installs in the rotor so it is positioned as in your picture #2: The rubber lip faces the knuckle and acts as an auxiliary dust shield at the rear of the seal. The lip type seal was original equipment in 1973-1989 rotors. Replacement seals for earlier applications may include it.
Gary, aka. Vaanth ------------------------ 1967 Plymouth Belvedere GTX, 440 1969 Plymouth Road Runner, 383 4-speed 1970 Challenger T/A, 340 Six Pak 1970 Challenger T/A, 440 Six Pack 1970 Dodge Charger 500, 383 1970 Plymouth Valiant Duster, 340 4-speed 1973 Plymouth Duster Twister, 360 1974 Dodge D200, 440 1977 Plymouth Fury Police, 400 1979 Chrysler Newport Police, 360 2017 Dodge Challenger T/A 392, custom ordered 2017 Ram 1500, 5.7, AT, 3.92SG 2021 Dodge Challenger R/T Scat Pack Shaker
[Re: Stanton]
#3262955
10/09/24 08:16 AM
10/09/24 08:16 AM
Posts: 11,015 North Dakota
6PakBee
North Dakota
Lip on an oil/grease seal typically always faces the lubricant. I say "typically" because I've run into one exception to this, the axle seals on a riding lawnmower transaxle.
[Re: GMP440]
#3263065
10/09/24 03:39 PM
10/09/24 03:39 PM
Posts: 13,762 md
mopars4ever
md
Wouldn`t the rubber part of the seal hit the wheel bearing if installed the wrong way?
Time just gets away from us I`m here until I`m not
[Re: mopars4ever]
#3263067
10/09/24 03:48 PM
10/09/24 03:48 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Wouldn`t the rubber part of the seal hit the wheel bearing if installed the wrong way? No. Cleared everything comfortably. That's why I was posting.
