Re: Tire pressure senders
[Re: cudaman1969]
#3256845
09/09/24 04:41 PM
09/09/24 04:41 PM
Posts: 13,260 Benton, IL.
DaveRS23
Master of nothing...
Benton, IL.
7 to 10 years typically on the batteries. We have had no problems with the Ebag or Amazon ones. $20 or so usually (though not always) gets a set of 4 delivered. Depending on the particular application, some come ready to install and the vehicle picks them up. Then, sometimes there is an additional step or two. With the ready access you are talking about, just buy the cheapest ones. Even IF they didn't last as long as OEs, they are cheap enough to not matter.
Master, again and still
[Re: DaveRS23]
#3256871
09/09/24 07:24 PM
09/09/24 07:24 PM
Posts: 4,369 Morrow, OH
markz528
Morrow, OH
For my 2012 caravan, my buddy who ran a tire store told me to but cheap ones at walmart. Around $25 for the whole set. So fat so good. They were preprogrammed.
[Re: markz528]
#3256923
09/10/24 07:18 AM
09/10/24 07:18 AM
Posts: 13,762 md
mopars4ever
md
I kinda like knowing when my tire is low on air.
Time just gets away from us I`m here until I`m not
[Re: cudaman1969]
#3256927
09/10/24 07:54 AM
09/10/24 07:54 AM
Posts: 1,436 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Need to know mhz rating and it helps to know the OEM part number for cross reference. Here's what works for my '21 Challenger, and they're available w/ steel stem like mine came with in addition to rubber version shown below.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3256976
09/10/24 12:30 PM
09/10/24 12:30 PM
Posts: 8,926 fredericksburg,va
cudaman1969
Itch Nutz
Itch Nutz
fredericksburg,va
Need to know mhz rating and it helps to know the OEM part number for cross reference. Here's what works for my '21 Challenger, and they're available w/ steel stem like mine came with in addition to rubber version shown below. How will I find a part number? Thanks to all replys above.
[Re: cudaman1969]
#3256980
09/10/24 12:37 PM
09/10/24 12:37 PM
Brad_Haak
Loudoun County, VA
Google "oem tpms part number <your_model_year> dodge challenger <your_model_type>" and see what comes back
[Re: cudaman1969]
#3257129
09/11/24 08:09 AM
09/11/24 08:09 AM
Brad_Haak
Loudoun County, VA
A search on Amazon will show metal stem valves also. OK These are the ones that I bought the last time: https://www.amazon.com/gp/product/B0BRQV2R7M
[Re: mopars4ever]
#3257134
09/11/24 08:26 AM
09/11/24 08:26 AM
cudaman1969
Itch Nutz
Itch Nutz
fredericksburg,va
I kinda like knowing when my tire is low on air. Ive had many cars since 1966 I know how to check the air in my tires.
[Re: cudaman1969]
#3257237
09/11/24 06:16 PM
09/11/24 06:16 PM
DaveRS23
Benton, IL.
You do know that the rims are the same so the stems interchange. And the sensors fit both stems, too.
Just trying to offer as much info on this as may be relevant.
[Re: DaveRS23]
#3257265
09/11/24 07:40 PM
09/11/24 07:40 PM
cudaman1969
Itch Nutz
Itch Nutz
fredericksburg,va
Just trying to offer as much info on this as may be relevant. That’s cool
[Re: dragon slayer]
#3262454
10/07/24 10:11 AM
10/07/24 10:11 AM
Posts: 13,762 md
mopars4ever
md
I would get them from a reputable online mopar dealer only.
