Tire pressure senders #3256842
09/09/24 04:33 PM
09/09/24 04:33 PM
fredericksburg,va
cudaman1969 Offline OP
Itch Nutz
Itch Nutz
fredericksburg,va
Just had tires changed out on 2015 Challenger, now having problem with the sensors in wheels. Been reading on them and it seams battery only last 9-10 years. Looking into buying some so what do I have to buy for car? Mopar SRT specific or just run of the mill (cheaper)? I planing on installing all 4 in a section of pvc pipe, sealing the ends then pressurizing to 35 psi, throw in the trunk, program into pcm
Re: Tire pressure senders [Re: cudaman1969] #3256845
09/09/24 04:41 PM
09/09/24 04:41 PM
Benton, IL.
DaveRS23 Offline
Master of nothing...
DaveRS23  Offline
Benton, IL.
7 to 10 years typically on the batteries.
We have had no problems with the Ebag or Amazon ones. $20 or so usually (though not always) gets a set of 4 delivered. Depending on the particular application, some come ready to install and the vehicle picks them up. Then, sometimes there is an additional step or two.
With the ready access you are talking about, just buy the cheapest ones. Even IF they didn't last as long as OEs, they are cheap enough to not matter.
twocents
Master, again and still
Re: Tire pressure senders [Re: DaveRS23] #3256871
09/09/24 07:24 PM
09/09/24 07:24 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
For my 2012 caravan, my buddy who ran a tire store told me to but cheap ones at walmart. Around $25 for the whole set. So fat so good. They were preprogrammed.
Re: Tire pressure senders [Re: markz528] #3256923
09/10/24 07:18 AM
09/10/24 07:18 AM
md
mopars4ever Online content
mopars4ever  Online Content
md
I kinda like knowing when my tire is low on air.
Time just gets away from us
I`m here until I`m not
Re: Tire pressure senders [Re: cudaman1969] #3256927
09/10/24 07:54 AM
09/10/24 07:54 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Need to know mhz rating and it helps to know the OEM part number for cross reference. Here's what works for my '21 Challenger, and they're available w/ steel stem like mine came with in addition to rubber version shown below.
Screen Shot 2021-12-29 at 2.57.11 PM.pngScreen Shot 2021-12-29 at 3.20.26 PM.png
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Tire pressure senders [Re: Brad_Haak] #3256976
09/10/24 12:30 PM
09/10/24 12:30 PM
fredericksburg,va
Itch Nutz
Itch Nutz
fredericksburg,va
How will I find a part number?
Thanks to all replys above.
Re: Tire pressure senders [Re: cudaman1969] #3256980
09/10/24 12:37 PM
09/10/24 12:37 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Google "oem tpms part number <your_model_year> dodge challenger <your_model_type>" and see what comes back
Re: Tire pressure senders [Re: cudaman1969] #3256982
09/10/24 12:46 PM
09/10/24 12:46 PM
Benton, IL.
DaveRS23 Offline
DaveRS23  Offline
Benton, IL.
Re: Tire pressure senders [Re: DaveRS23] #3257049
09/10/24 07:12 PM
09/10/24 07:12 PM
fredericksburg,va
Itch Nutz
Itch Nutz
fredericksburg,va
Originally Posted by DaveRS23
Thanks Dave but Mine are metal stems
Re: Tire pressure senders [Re: cudaman1969] #3257069
09/10/24 09:33 PM
09/10/24 09:33 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
A search on Amazon will show metal stem valves also.
Re: Tire pressure senders [Re: stumpy] #3257097
09/10/24 11:13 PM
09/10/24 11:13 PM
fredericksburg,va
Itch Nutz
Itch Nutz
fredericksburg,va
OK
Re: Tire pressure senders [Re: cudaman1969] #3257129
09/11/24 08:09 AM
09/11/24 08:09 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
OK
These are the ones that I bought the last time: https://www.amazon.com/gp/product/B0BRQV2R7M
Re: Tire pressure senders [Re: mopars4ever] #3257134
09/11/24 08:26 AM
09/11/24 08:26 AM
fredericksburg,va
Itch Nutz
Itch Nutz
fredericksburg,va
Ive had many cars since 1966 I know how to check the air in my tires.
Re: Tire pressure senders [Re: Brad_Haak] #3257135
09/11/24 08:27 AM
09/11/24 08:27 AM
fredericksburg,va
Itch Nutz
Itch Nutz
fredericksburg,va
OK
I’ll order them today.
Re: Tire pressure senders [Re: cudaman1969] #3257138
09/11/24 08:33 AM
09/11/24 08:33 AM
Benton, IL.
DaveRS23 Offline
DaveRS23  Offline
Benton, IL.
"I planing on installing all 4 in a section of pvc pipe, sealing the ends then pressurizing to 35 psi, throw in the trunk, program into pcm"
shruggy
Re: Tire pressure senders [Re: DaveRS23] #3257184
09/11/24 12:08 PM
09/11/24 12:08 PM
fredericksburg,va
Itch Nutz
Itch Nutz
fredericksburg,va
shruggy
Prefere the metal bolt in type, will install better in the tube with nut and if I change my idea I can always install in rims
Re: Tire pressure senders [Re: cudaman1969] #3257237
09/11/24 06:16 PM
09/11/24 06:16 PM
Benton, IL.
DaveRS23 Offline
DaveRS23  Offline
Benton, IL.
You do know that the rims are the same so the stems interchange. And the sensors fit both stems, too.
Just trying to offer as much info on this as may be relevant.
Re: Tire pressure senders [Re: DaveRS23] #3257265
09/11/24 07:40 PM
09/11/24 07:40 PM
fredericksburg,va
Itch Nutz
Itch Nutz
fredericksburg,va
That’s cool
Re: Tire pressure senders [Re: cudaman1969] #3262453
10/07/24 10:08 AM
10/07/24 10:08 AM
VA
dragon slayer Offline
VA
So after multiple tries on Ebay with 3 year warranty sensors, I found most of the sellers are the same despite state and name changes. Chinese knock offs. Twice they cancelled my order saying sensor did not work when they tested them and refunded my money. Despite having multiple listing available. Then purchase a set of CDWTP. They could not be activated via 3 different programs. So sent back for refund. Most of them are knock offs, may have same ID, and who knows how long they will last.
In the end Tire discount matched a Rock Auto price of $31 ea, but they come with 6yr/72 mile warranty. I wasted a lot of time trying on the internet.
The orig Mopar that came out have far more registration data ink stamped on the sensor, then these knock offs.
I recommend going with a reputable boxed set and forgetting Ebay versions.
Re: Tire pressure senders [Re: dragon slayer] #3262454
10/07/24 10:11 AM
10/07/24 10:11 AM
md
md
I would get them from a reputable online mopar dealer only.
