TA 8-3/4 Sure Grip
#3262372
10/06/24 09:26 PM
10/06/24 09:26 PM
Posts: 2,405 White Plains, NY
VCODE
White Plains, NY
Did a TA with the 8-3/4 rear come with the Cone type sure grip.
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: TA 8-3/4 Sure Grip
[Re: VCODE]
#3262381
10/06/24 10:24 PM
10/06/24 10:24 PM
Posts: 9 West Georgia, USA
Vaanth
West Georgia, USA
The Challenger T/A, and AAR 'Cuda, used the 2881489 (aka "489") differential carrier assembly in its 8-3/4 rear axle with the "cone" type Borg Warner Spin Resistant (# 2881343) Sure Grip.
1967 Plymouth Belvedere GTX, 440 1969 Plymouth Road Runner, 383 4-speed 1970 Challenger T/A, 340 Six Pak 1970 Challenger T/A, 440 Six Pack 1970 Dodge Charger 500, 383 1970 Plymouth Valiant Duster, 340 4-speed 1971 Dodge D100, 383 1973 Plymouth Duster Twister, 360 1974 Dodge D200, 440 1977 Plymouth Fury Police, 400 1979 Chrysler Newport Police, 360 1984 Dodge Ramcharger, 360 2017 Dodge Challenger T/A 392, custom ordered 2017 Ram 1500, 5.7, AT, 3.92SG 2021 Dodge Challenger R/T Scat Pack Shaker
[Re: VCODE]
#3262396
10/07/24 02:50 AM
10/07/24 02:50 AM
Posts: 43,793 Bend,OR USA
Cab_Burge
What was it SPD (schedule production date) and which factory was it made at?
[Re: Cab_Burge]
#3262416
10/07/24 07:53 AM
10/07/24 07:53 AM
VCODE
White Plains, NY
What was it SPD (schedule production date) and which factory was it made at? SPD 414 Hamtramck It is original to this TA All the markings and paint daubs where there Thanks
[Re: Vaanth]
#3262417
10/07/24 07:54 AM
10/07/24 07:54 AM
VCODE
White Plains, NY
The Challenger T/A, and AAR 'Cuda, used the 2881489 (aka "489") differential carrier assembly in its 8-3/4 rear axle with the "cone" type Borg Warner Spin Resistant (# 2881343) Sure Grip. The Factory Parts Book does not have any info on the Cone type sure grip, nothing. Thanks
[Re: fastmark]
#3262418
10/07/24 07:56 AM
10/07/24 07:56 AM
VCODE
White Plains, NY
The TA and AAR were well into the run of 1970 so the only suregrip available would have been the cone type and the 489 carrier with the std 3.55 or the options 3.91 ratio. You could still get the 741 small pinion and they were also available with a sure grip. I have personally never taken one of those out of a car to see what suregrip it had. I was a little surprised to see this sure grip. I always had the clutch sure grip in my Dana 60 Where to find parts Thanks
[Re: EV2RTSE]
#3262464
10/07/24 11:42 AM
10/07/24 11:42 AM
VCODE
White Plains, NY
Thanks, I did see that. Mine looks pretty good just not sure about the way the large gears are against the cone.
[Re: fastmark]
#3262679
10/08/24 07:40 AM
10/08/24 07:40 AM
VCODE
White Plains, NY
Before any modifications are done, I’d follow the service manual instructions for testing of the unit you have. Spoke with Doctor Diff and he has a shim kit if needed. Back in the day it was serviced as a unit. Today some machining may be done. Thanks
[Re: VCODE]
#3262710
10/08/24 09:13 AM
10/08/24 09:13 AM
Posts: 75,292 A gulag near you.
JohnRR
A gulag near you.
The TA and AAR were well into the run of 1970 so the only suregrip available would have been the cone type and the 489 carrier with the std 3.55 or the options 3.91 ratio. You could still get the 741 small pinion and they were also available with a sure grip. I have personally never taken one of those out of a car to see what suregrip it had. I was a little surprised to see this sure grip. I always had the clutch sure grip in my Dana 60 Where to find parts Thanks The Dana 60 is a completely different animal, but if your dana 60 was a 1970 or newer then it had a track lock, instead of the Spicer clutch type, which is not as robust as the Spicer clutch type.
Mainstream Media is the new Pravda
[Re: VCODE]
#3262712
10/08/24 09:20 AM
10/08/24 09:20 AM
JohnRR
A gulag near you.
Before any modifications are done, I’d follow the service manual instructions for testing of the unit you have. Spoke with Doctor Diff and he has a shim kit if needed. Back in the day it was serviced as a unit. Today some machining may be done. Thanks Don't waste your time, or money. To machine the cone type it's going to require complete disassembly and you'll want to change your bearings , ... unless the car only has a few thousand original miles .... the cone type grinds the cones up every time you take a turn, which generates tiny metal particles that float around in the oil and gets run thru the bearings and the gear teeth, high mileage units will have tiny marks in the surface of the bearings and gears from all that metal, they take on a grayish haze from it. It's going to cost almost as much as just buying a clutch type from Dr. Diff and rebuilding the chuck. The BW cone type is a piece of garbage by design.
[Re: JohnRR]
#3262839
10/08/24 03:40 PM
10/08/24 03:40 PM
VCODE
White Plains, NY
Before any modifications are done, I’d follow the service manual instructions for testing of the unit you have. Spoke with Doctor Diff and he has a shim kit if needed. Back in the day it was serviced as a unit. Today some machining may be done. Thanks Don't waste your time, or money. To machine the cone type it's going to require complete disassembly and you'll want to change your bearings , ... unless the car only has a few thousand original miles .... the cone type grinds the cones up every time you take a turn, which generates tiny metal particles that float around in the oil and gets run thru the bearings and the gear teeth, high mileage units will have tiny marks in the surface of the bearings and gears from all that metal, they take on a grayish haze from it. It's going to cost almost as much as just buying a clutch type from Dr. Diff and rebuilding the chuck. The BW cone type is a piece of garbage by design. Some good info John Thanks
[Re: JohnRR]
#3262842
10/08/24 04:07 PM
10/08/24 04:07 PM
Posts: 21,918 Kirkland, Washington
Pacnorthcuda
Before any modifications are done, I’d follow the service manual instructions for testing of the unit you have. Spoke with Doctor Diff and he has a shim kit if needed. Back in the day it was serviced as a unit. Today some machining may be done. Thanks Don't waste your time, or money. To machine the cone type it's going to require complete disassembly and you'll want to change your bearings , ... unless the car only has a few thousand original miles .... the cone type grinds the cones up every time you take a turn, which generates tiny metal particles that float around in the oil and gets run thru the bearings and the gear teeth, high mileage units will have tiny marks in the surface of the bearings and gears from all that metal, they take on a grayish haze from it. It's going to cost almost as much as just buying a clutch type from Dr. Diff and rebuilding the chuck. The BW cone type is a piece of garbage by design. True, but either way you are looking at bearing replacement anyway, so the cost of the diff unit is extra no matter what route you take.
