TA 8-3/4 Sure Grip #3262372
10/06/24 08:26 PM
10/06/24 08:26 PM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
Did a TA with the 8-3/4 rear come with the Cone type sure grip.
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: TA 8-3/4 Sure Grip [Re: VCODE] #3262381
10/06/24 09:24 PM
10/06/24 09:24 PM
West Georgia, USA
Vaanth Offline
Vaanth  Offline
West Georgia, USA
The Challenger T/A, and AAR 'Cuda, used the 2881489 (aka "489") differential carrier assembly in its 8-3/4 rear axle with the "cone" type Borg Warner Spin Resistant (# 2881343) Sure Grip.
Gary, aka. Vaanth
1967 Plymouth Belvedere GTX, 440
1969 Plymouth Road Runner, 383 4-speed
1970 Challenger T/A, 340 Six Pak
1970 Challenger T/A, 440 Six Pack
1970 Dodge Charger 500, 383
1970 Plymouth Valiant Duster, 340 4-speed
1973 Plymouth Duster Twister, 360
1974 Dodge D200, 440
1977 Plymouth Fury Police, 400
1979 Chrysler Newport Police, 360
2017 Dodge Challenger T/A 392, custom ordered
2017 Ram 1500, 5.7, AT, 3.92SG
2021 Dodge Challenger R/T Scat Pack Shaker
Re: TA 8-3/4 Sure Grip [Re: VCODE] #3262396
10/07/24 01:50 AM
10/07/24 01:50 AM
What was it SPD (schedule production date) and which factory was it made at?
Re: TA 8-3/4 Sure Grip [Re: Cab_Burge] #3262401
10/07/24 02:32 AM
10/07/24 02:32 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
The TA and AAR were well into the run of 1970 so the only suregrip available would have been the cone type and the 489 carrier with the std 3.55 or the options 3.91 ratio. You could still get the 741 small pinion and they were also available with a sure grip. I have personally never taken one of those out of a car to see what suregrip it had.
Re: TA 8-3/4 Sure Grip [Re: Cab_Burge] #3262416
10/07/24 06:53 AM
10/07/24 06:53 AM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
SPD 414 Hamtramck
It is original to this TA
All the markings and paint daubs where there
Re: TA 8-3/4 Sure Grip [Re: Vaanth] #3262417
10/07/24 06:54 AM
10/07/24 06:54 AM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
The Factory Parts Book does not have any info on the Cone type sure grip, nothing.
Re: TA 8-3/4 Sure Grip [Re: fastmark] #3262418
10/07/24 06:56 AM
10/07/24 06:56 AM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
I was a little surprised to see this sure grip. I always had the clutch sure grip in my Dana 60
Where to find parts
Re: TA 8-3/4 Sure Grip [Re: VCODE] #3262445
10/07/24 09:21 AM
10/07/24 09:21 AM
NJ
EV2RTSE Offline
EV2RTSE  Offline
NJ
I wonder if it was a cost cutting measure or something. From what I understand the cone type isn't really rebuildable per se but you can get a shim pack for the cones, Dr Diff has them.
https://www.doctordiff.com/8-3-4-cone-sure-grip-shim-pack.html
I ditched the one in the 489 case in my R/T. The car had a hard life and a lot of miles on it so it was going to get a new unit anyway. I replaced it with the helical gear type, overkill probably but I think they're supposed to be the best.
https://www.doctordiff.com/8-3-4-helical-gear-sure-grip-sure-trac.html
Re: TA 8-3/4 Sure Grip [Re: EV2RTSE] #3262464
10/07/24 10:42 AM
10/07/24 10:42 AM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
Thanks, I did see that.
Mine looks pretty good just not sure about the way the large gears are against the cone.
Re: TA 8-3/4 Sure Grip [Re: VCODE] #3262672
10/08/24 05:57 AM
10/08/24 05:57 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Before any modifications are done, I’d follow the service manual instructions for testing of the unit you have.
Re: TA 8-3/4 Sure Grip [Re: fastmark] #3262679
10/08/24 06:40 AM
10/08/24 06:40 AM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
Spoke with Doctor Diff and he has a shim kit if needed. Back in the day it was serviced as a unit. Today some machining may be done.
Re: TA 8-3/4 Sure Grip [Re: VCODE] #3262710
10/08/24 08:13 AM
10/08/24 08:13 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Where to find parts
The Dana 60 is a completely different animal, but if your dana 60 was a 1970 or newer then it had a track lock, instead of the Spicer clutch type, which is not as robust as the Spicer clutch type.
Mainstream Media is the new Pravda
Re: TA 8-3/4 Sure Grip [Re: VCODE] #3262712
10/08/24 08:20 AM
10/08/24 08:20 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Don't waste your time, or money. To machine the cone type it's going to require complete disassembly and you'll want to change your bearings , ... unless the car only has a few thousand original miles .... the cone type grinds the cones up every time you take a turn, which generates tiny metal particles that float around in the oil and gets run thru the bearings and the gear teeth, high mileage units will have tiny marks in the surface of the bearings and gears from all that metal, they take on a grayish haze from it. It's going to cost almost as much as just buying a clutch type from Dr. Diff and rebuilding the chuck.
The BW cone type is a piece of garbage by design.
Re: TA 8-3/4 Sure Grip [Re: JohnRR] #3262839
10/08/24 02:40 PM
10/08/24 02:40 PM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
Some good info John
Re: TA 8-3/4 Sure Grip [Re: JohnRR] #3262842
10/08/24 03:07 PM
10/08/24 03:07 PM
Kirkland, Washington
Pacnorthcuda Offline
True, but either way you are looking at bearing replacement anyway, so the cost of the diff unit is extra no matter what route you take.
Re: TA 8-3/4 Sure Grip [Re: Pacnorthcuda] #3262910
10/08/24 09:30 PM
10/08/24 09:30 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
the cost of a new sure grip will be offset by the work to make the cone type work again , but only for a limited time and it will be destroying the new bearings ... it's garbage by design , save yourself the misery.
My 69 Dart GTS 383 car has 57k original miles on it's 3.91 BW cone type , the cone type is coming out and will never go back in ... I buy 741 chucks with 2.76 clutch types to rob the sure grips and toss the rest in the metal scrap pile .
