99 Dakota dragging brake problem #3262818
10/08/24 01:48 PM
10/08/24 01:48 PM
541 slobovia
A990 Offline OP
A990  Offline OP
541 slobovia
How can I tell if a piston is causing this, or if its a collapsed brake hose?
(I really don't like dumping good parts till I find the problem)
btw, The wheel bearing grease is scorched. I drove some hilly streets, and the temp gun shows 100 degree difference. Also noticeably more effort to spin the wheel.
TIA
Ken
Re: 99 Dakota dragging brake problem [Re: A990] #3262835
10/08/24 02:20 PM
10/08/24 02:20 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Pump up the brakes, then open the bleeder valve. See if the wheel turns. If it does, it was the brake hose.
Re: 99 Dakota dragging brake problem [Re: John Brown] #3262841
10/08/24 03:03 PM
10/08/24 03:03 PM
541 slobovia
A990 Offline OP
A990  Offline OP
541 slobovia
Thanks!
I'll report back after while.
