Can full manual reverse 727 valve body be converted to auto
#3262560
10/07/24 05:15 PM
10/07/24 05:15 PM
Posts: 1,056 Slidell, La.
doctor_mopar
Slidell, La.
Have a big block 727 recently rebuilt . It has a full manual reverse pattern valve body . Need to convert back to forward pattern automatic shifting . Can the valve body be converted back ? Thanks
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: Can full manual reverse 727 valve body be converted to auto
[Re: doctor_mopar]
#3262579
10/07/24 06:29 PM
10/07/24 06:29 PM
Posts: 3,241 Michigan
A727Tflite
Have a big block 727 recently rebuilt . It has a full manual reverse pattern valve body . Need to convert back to forward pattern automatic shifting . Can the valve body be converted back ? Thanks Just sell the valve body and get a standard one. I have stock units. Give me the PK number off the side of the trans. PM if interested.
[Re: calrobb2000]
#3262658
10/08/24 01:22 AM
10/08/24 01:22 AM
Posts: 10,397 A Red State
SNK-EYZ
A Red State
hi
maybe , it may have the governor blocked or removed
talk to the builder .
find out what v b it has in there now . That's what I was thinking. The guy that built the reverse pattern manual trans in our Dart had said we couldn't just swap the valve body on ours because of the governor.
[Re: doctor_mopar]
#3262734
10/08/24 09:24 AM
10/08/24 09:24 AM
doctor_mopar
Slidell, La.
I should have phrased things differently . The transmission was built many years ago . It only has about 5 miles on it from a test drive . It is out of the car. I can not locate the last guy who built it . I have a builder who will fix any changes thr transmission needs to go back full automatic . He said for me to get another valve body to build , and that I probably need a governor . I was wondering if a full manual body could be converted back . He said no , and I thought no , but thought I would aak here because of the broad knowledge base here .
[Re: doctor_mopar]
#3262778
10/08/24 11:32 AM
10/08/24 11:32 AM
Posts: 27,109 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I was wondering if a full manual body could be converted back . The two parts that are different in a RMVB are the steel separator plate and the cast transfer plate. The separator plate can be replaced with a stock one but the transfer plate has several channel partitions removed (marked in red in pic below), so it can never be returned to stock. As advised, just get another stock VB. You can check for a missing governor by blowing air into the governor ports at the rear of the case...if the parts are missing, the air will rush right through unrestricted.
[Re: John_Kunkel]
#3262782
10/08/24 11:50 AM
10/08/24 11:50 AM
doctor_mopar
Slidell, La.
Thank You for that explanation John !
[Re: John_Kunkel]
#3263006
10/09/24 11:43 AM
10/09/24 11:43 AM
Posts: 20,740 north of coder
moparx
I was wondering if a full manual body could be converted back . The two parts that are different in a RMVB are the steel separator plate and the cast transfer plate. The separator plate can be replaced with a stock one but the transfer plate has several channel partitions removed (marked in red in pic below), so it can never be returned to stock. As advised, just get another stock VB. You can check for a missing governor by blowing air into the governor ports at the rear of the case...if the parts are missing, the air will rush right through unrestricted. what is the difference in the transfer plate castings between the reverse pattern and the forward pattern manual valve body ?
[Re: A727Tflite]
#3263508
10/11/24 07:16 PM
10/11/24 07:16 PM
doctor_mopar
Slidell, La.
A727Tflite Private message sent
[Re: doctor_mopar]
#3263516
10/11/24 08:21 PM
10/11/24 08:21 PM
A727Tflite
A727Tflite Private message sent Sorry, I missed it. I’ll handle it tomorrow.
