Cam Run in With Edelbrock Heads SB 360 #3262394
10/07/24 01:15 AM
10/07/24 01:15 AM
Goat Rodeo
drago Offline OP
drago  Offline OP
Goat Rodeo
Hello Gents,
Looking to run in a Mopar Perf solid lifter flat tappet cam in a 360 SB with Edelbrock heads.
Getting conflicting information about the valve spring pressures in these heads. Not sure whether it's too much for run in.
The heads are part no #60779, the valve spring is supposed to be part no #5767.
The cam is a purple shaft P4529970 .526 lift solid lifter flat tappet.
Am I over thinking this? just want no cam failure dramas.
Thank you all for any advice.
Re: Cam Run in With Edelbrock Heads SB 360 [Re: drago] #3262399
10/07/24 02:59 AM
10/07/24 02:59 AM
What pressures do you have, seat and open? shruggy
