1969 A12 PCV hose to carb connector
#3261853
10/04/24 03:57 AM
10/04/24 03:57 AM
Posts: 88 usa
bdgtfb
usa
Can anyone tell me if the steel pipe which fits into the center carb just above the base plate for attaching the PCV rubber hose to should be loose and easily pulled out? Thanks for any help
Re: 1969 A12 PCV hose to carb connector
[Re: TJP]
#3262241
10/06/24 01:29 AM
10/06/24 01:29 AM
Posts: 6,670 Abilene, Texas
fastmark
Abilene, Texas
Loctite has a sleeve sealer. I think it’s green. You could use it. On a side note, the 1/8” vacuum fittings come out on a regulator basis. I just rebuilt a set of carbs from a 24,000 mile Superbird and all three of the vacuum fittings came out of the carb bodies because it still had the original vacuum hose and it would not let the steel release.
[Re: fastmark]
#3262242
10/06/24 01:37 AM
10/06/24 01:37 AM
fastmark
Abilene, Texas
Here they are all done. He did not want them plated so I just did my special cleaning on them. It brings out what’s left of the plating that is still on the carbs. They were in pretty good shape
