Engine doesn't start with key in start position #3261229
10/01/24 12:39 PM
10/01/24 12:39 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Here's a fun one...
1971 Imperial with an early 90s era Mopar electronic ignition retrofit kit. Yes, the old orange box that still works.
The car has been performing beautifully. It fired up at the first twist of the key. I drove it about 20 minutes and the car didn't want to restart. Now, it will only start when I release the key. Or, if I put the key in the run position and jump the solenoid.
Yes, the single row ballast resistor is good. 1.5 ohm as designed, otherwise it would die when I released the key.
I removed the starter solenoid wire to reduce voltage draw. Testing wires at the ballast resistor I get 12.3 volts at the brown (start) wire with the key in start. No voltage with key in run. Blue (run) wire shows 11 volts in run and nothing in start. A bit low but it functions fine.
I pulled the bulkhead connector and cleaned the already pretty clean terminals on both sides.
No change.
Ignition switch is good.
Wiring is good.
Terminals are good.
Battery is good (a week old).
Why won't it start properly with the key?
- Stu Harmon
Re: Engine doesn't start with key in start position [Re: feets] #3261253
10/01/24 01:54 PM
10/01/24 01:54 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by feets
Here's a fun one...
No change.
Wiring is good.
Terminals are good.
You are checking V at the ballast output terminal, have you checked V at the coil? Seems like that 12.3V isn't getting to the coil. Possibly a bad crimp?
Could try a jumper to the coil
Also verify the module is getting 12V as I've had a few that were wired to the wrong side of the ballast wink
Next check your grounds and possibly even run a ground wire from the block to the module
keep us posted beer
Re: Engine doesn't start with key in start position [Re: TJP] #3261269
10/01/24 03:10 PM
10/01/24 03:10 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
keep us posted beer
Voltage at the coil is good, otherwise it wouldn't run. Ignition 2 (start) bypasses the resistor and shoots voltage to the coil. Ignition 1 (run) goes through the ballast resistor, down the same connection used by Ignition 2, and to the coil. If the coil lead was faulty the lower voltage from the ballast resistor wouldn't make the engine run.
Grounds have got to be good because the engine runs.
System is wired properly because I've been driving the car all over town. The Ignition 2 issue just popped up. The car still runs, you just have to hope it catches on key release or jump the solenoid.
- Stu Harmon
Re: Engine doesn't start with key in start position [Re: feets] #3261277
10/01/24 03:44 PM
10/01/24 03:44 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
keep us posted beer
Did you verify that Ignition 2 is making it to the coil with the key in start? Because that is only handled by the ignition switch and the bit of wire that goes from Ign 2 to the ballast, coil side of the ballast to bypass it.
As for the rest of the things, do not assume anything. Electricity can be real weird and do odd things when grounds are bad or connections are poor.
Re: Engine doesn't start with key in start position [Re: Sniper] #3261288
10/01/24 04:36 PM
10/01/24 04:36 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I did not ohm out the ign 2 wire between the ballast and coil. It's the same piece of wire that runs the coil on lower voltage from ign 1. The engine runs so that section of wire is good.
- Stu Harmon
Re: Engine doesn't start with key in start position [Re: feets] #3261295
10/01/24 05:17 PM
10/01/24 05:17 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Not talking about that wire. Talking about the one from the ignition switch to the coil side of the ballast. In start, what is the voltage at the coil? If it's not there work your way back till you find it, ultimately it comes out of the ignition switch.
It may very well be a case of your starter loading down the system so much there is not enough juice for the coil to work, but once you release the key the voltage goes up enough to fire the coil.
Re: Engine doesn't start with key in start position [Re: feets] #3261297
10/01/24 05:29 PM
10/01/24 05:29 PM
PA
maxwedge1 Offline
maxwedge1  Offline
PA
if all wiring and voltages check out ok replace the magnetic pickup...i have twice had the problem you described and the pickup cured it.
Re: Engine doesn't start with key in start position [Re: maxwedge1] #3261313
10/01/24 06:36 PM
10/01/24 06:36 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
That would be a bit unusual for direct voltage to not work but indirect voltage works.
- Stu Harmon
Re: Engine doesn't start with key in start position [Re: Sniper] #3261318
10/01/24 07:00 PM
10/01/24 07:00 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
If I put the key in the run position and jump the starter the engine fires up immediately.
That would negate the starter draw idea.
It should also negate the wire from the ballast resistor to the coil since that part of the wire is used in both situations.
The start wire shows 12 volts at the ballast resistor when the key is turned.
- Stu Harmon
Re: Engine doesn't start with key in start position [Re: feets] #3261320
10/01/24 07:01 PM
10/01/24 07:01 PM
Central Michigan
N
nuthinbutmopar Offline
N
Central Michigan
If the ignition switch cranks the motor and it runs normally when the key is released to the "RUN" position, the coil IS NOT getting power with the switch in the "START" position. I haven't seen where you checked coil voltage with the key in "START", but I'd bet that if you do, it's either 0 or low. It should be 12V when cranking as it bypasses the ballast to give a hotter spark when cranking.
Re: Engine doesn't start with key in start position [Re: feets] #3261353
10/01/24 09:03 PM
10/01/24 09:03 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Also verify the module is getting 12V as I've had a few that were wired to the wrong side of the ballast that caused intermittent no start issues;)
keep us posted beer
I know all of that and agree, but your symptoms indicate power is not getting to the coil in the START position or their is another issue IE: Ground, Module wiring, Voltage drop (A lot of batteries are doing strange things these days), possible pickup coil as mentioned, that sounds strange but so is the problem.
The best part is it sounds like a SOLID fail vs intermittent.
keep us posted beer
Re: Engine doesn't start with key in start position [Re: TJP] #3261356
10/01/24 09:11 PM
10/01/24 09:11 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Veddy interesting...
The car fired up as I released the key this evening so I took the car to dinner.
After dinner the car was hard to start. I finally got it started but as I was getting ready to leave it died. The car would not restart. There was another ignition box in the trunk. The box was marked "good ECU". I popped it in and the car started normally.
- Stu Harmon
Re: Engine doesn't start with key in start position [Re: feets] #3261362
10/01/24 10:24 PM
10/01/24 10:24 PM
AndyF Offline
AndyF  Offline
When you say it won't start with the key in the start position does that means it cranks but doesn't fire? If so, then for some reason the ignition system either isn't getting the correct voltage in the start position, or the ignition box doesn't like the voltage that it is getting. Since it starts with a different ignition box that points to the old box not liking the full 12 volts. Which is a weird problem, but as those electronic devices get old they can develop weird failure modes.
I can't tell you why it would start with the key on and jumping the solenoid but I suppose the voltage that the ignition box saw in that situation was different somehow.
I had an older car that would randomly shut off and restart while driving. Replaced the ECU and the problem went away. Would take an EE and a lab full of equipment to find the root cause of the problem. Computer repair guys just call it "bulging capacitors". When an older PC starts to do weird stuff they just say "bulging capacitors" and replace the motherboard.
Re: Engine doesn't start with key in start position [Re: AndyF] #3261980
10/04/24 02:26 PM
10/04/24 02:26 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Yeah, I should have clarified. No spark condition.
This morning I got no starter. Jumping the relay got the starter. Turning the key gave me 12 volts at the start wire going to the relay but no start. Pumping 12 volts into the switch terminal on the relay gave me a starter.
Cycling the shifter lever brought back normal function.
Now, the tenp gauge doesn't work. 🙄
- Stu Harmon
Re: Engine doesn't start with key in start position [Re: feets] #3262127
10/05/24 10:29 AM
10/05/24 10:29 AM
moparx Offline
moparx  Offline
as Annaroseannadanna [not sure of the spelling - an old SNL character] always said : "it's ALWAYS something............."
beer
Re: Engine doesn't start with key in start position [Re: moparx] #3262134
10/05/24 10:40 AM
10/05/24 10:40 AM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
beer
My old buddy Cecil used to say "if it ain't one thing, it's two."
Re: Engine doesn't start with key in start position [Re: feets] #3262140
10/05/24 11:02 AM
10/05/24 11:02 AM
AndyF Offline
AndyF  Offline
Sounds like you have multiple problems going on. Or perhaps, just one really bad ground connection somewhere.
Re: Engine doesn't start with key in start position [Re: AndyF] #3262465
10/07/24 10:43 AM
10/07/24 10:43 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
All part of the fun of a new to me car.
The temp sending unit tests good. The wire from the unit to the bulkhead is good. I'll have to get under the dash and check for a good signal coming through there.
- Stu Harmon
