Holley 12-846 HP Billet Fuel Pressure Regulator "NEW"
[Re: moparts]
#3261020
09/30/24 07:45 PM
09/30/24 07:45 PM
Posts: 252 Northwest Indiana
19Coronet66
Northwest Indiana
For sale is a "NEW" in the box Holley HP Billet adjustable fuel pressure regulator. Part number 12-846. EFI applications. Bypass style. Adjustable from 15-65 PSI. -8AN o-ring inlet. -8AN o-ring outlet. -6AN o-ring return. $160 shipped in the 48 states. PM if interested. https://www.jegs.com/i/Holley/510/12-846/10002/-1
Re: For Sale - Race Parts - 4th Quarter
[Re: 6PAX]
#3261163
10/01/24 09:52 AM
10/01/24 09:52 AM
Posts: 215 Illinois
gearhead01
Illinois
FALL GARAGE SALE
Thank you Moparts for the Ad Time to get somethings out of the garage to someone who can use them. Prices reduced! All items plus shipping from 61073 unless noted Ship or can meet within 35 miles of Rockford, IL Cashier's Check or Money Order
Pair Rancho RS99116 Single Adjustable Rear Shocks 16-1/2" to 22-1/2" Eye to Eye - $80 Moroso 65961 Air Pan Kit for 4500 Dominator - New in Box $10 Fiberglass (Not Plastic) Racing Seat with Cover You need this for your Gasser Build! - PICK UP ONLY - $40 or best offer
Please message me on the Board Thanks for looking, John
1971 Satellite Sebring Plus - 14.46 @ 95.43 1977 Road Runner - N/B 11.02@ 119 Drag Radials
CR12B early B-body fuel tank
[Re: moparts]
#3261992
10/04/24 04:04 PM
10/04/24 04:04 PM
Posts: 786 Midwest
fuseable
Midwest
CR12B early B-body fuel tank, has sump box welded in, sump box is about 1" below tank with 4" to 5" tall inside tank. Tank was coated inside and out by a company called Tank Renu. here is a link. https://www.gastankrenu.com/Also has Aeromotive fuel filter with -10 outlet, -8 return,-6 vent. Also, can use a stock pickup, I have a new one to go with it. to plug the hole where it goes. 400$ Prefer local pick up, will ship at buyer's expense, I think it would be pretty expensive though. Located in Kansas City area. Pm if interested.
New Forged Small Block 360 & 5.9 Magnum Stroker Assembly-408
[Re: Rocket]
#3262282
10/06/24 12:13 PM
10/06/24 12:13 PM
Posts: 927 CT
Rocket
CT
I have a new SCAT forged rotating assembly for 360 & 5.9 Magnum Mopar engines. All parts are new high-quality parts. Final cubic inches will be 408”. The assembly includes the following parts.
• SCAT forged 4.000” crankshaft part # 4-360-4000-6123 • SCAT forged H-beam connecting rods with APR 2000 bolts part # 2-360-6123-2124A • Diamond Forged flattop 4.030” bore pistons (0.030” oversize) part # 51026 • Trend wrist pins - 0.984” part # TPD-G9842750155 • Diamond wrist pin locks • Mahle file fit ring set with Moly ductile iron top rings part # MAH4035MS • Speed Pro Tri metal Competition Series rod bearings part # 8-7125CH • Clevite P-Series full groove main bearings part # MS-1266P
If you are looking for a 360 stroker with lower compression, I can substitute the pistons and connecting rods for new SRP 4.030” dished pistons part # 220156 (16.9 cc piston head volume) and new Eagle H-beam rods part # CRS6123C3D (360 stroker assembly only).
These rotating assemblies will need balancing.
The price for this complete kit with the Diamond flat top pistons and SCAT rods is $2,750 plus shipping cost.
The price for this complete kit with the SRP dished pistons and the Eagle H-beam rods is $2,600 plus shipping cost.
I also have a similar stroker assembly for a 340 with new Diamond 4.060” (0.020” overbore) flat top pistons, Perfect Circle file fit ring set with Moly ductile iron top rings part # 315-0036.065 and Speed Pro Tri metal Competition Series rod bearings part # 8-7125CH. Displacement would be 414 ci. This rotating assembly will need balancing.
The price for the complete 340 kit is $2,750 plus shipping cost.
I can also meet in CT.
Email me at procketrichard@hotmail.com with any questions or for more pictures.
Small Block I Beam Connecting Rods by Childs & Albert - New
[Re: Rocket]
#3262286
10/06/24 12:19 PM
10/06/24 12:19 PM
Posts: 927 CT
Rocket
CT
I have a new set of forged I beam connecting rods by Childs & Albert in the original box. American made in the 1990’s. Part number is 340-15B-2. Center to center length is 6.125”. Big end is for rod journals of 2.125” (small block Mopar) and small end is for wrist pins of 0.927”. Weight per rod is ~ 685 grams. See spec card in the pictures.
These are very stout rods, suitable for a high horsepower build.
Price is $850 shipped in the lower 48 states. I will ship internationally for the added cost.
Mopar W2 / W5 Exhaust Roller Rockers 1.5 Ratio - New
[Re: Rocket]
#3262287
10/06/24 12:26 PM
10/06/24 12:26 PM
Posts: 927 CT
Rocket
CT
New Mopar Performance W2 /W5 exhaust roller rockers. I have quite a few of these so if you need more than one just ask.
Price is $40 each shipped in the lower 48 states. Set of eight rockers is $280 shipped in the lower 48 states.
I will ship internationally for the additional cost.
