451 crank balancing
#3261109
09/30/24 11:28 PM
09/30/24 11:28 PM
Posts: 75 norcal
JLaSalle
norcal
Do these counterweight holes look correct for a 451 with 7.25" diameter counterweghts?I know the rotating assembly is light but didnt expect this much swiss cheese with the counterweghts turned down.I could be wrong lol.Mahle 1.32" pistons,6.76 molnar h beams,.990,2.20.
1967 Coronet R/T 9.83 134mph. 470 cid st.6 heads 10x pro et track champion
Re: 451 crank balancing
[Re: JLaSalle]
#3261148
10/01/24 07:56 AM
10/01/24 07:56 AM
Posts: 75,353 A gulag near you.
JohnRR
A gulag near you.
The only way to be sure is to have it checked by a competent engine builder , if you bought this stuff second hand assume NOTHING .
Mainstream Media is the new Pravda
[Re: AndyF]
#3261193
10/01/24 10:30 AM
10/01/24 10:30 AM
Posts: 75 norcal
JLaSalle
norcal
Andy this a new Ohio Crankshaft.
[Re: JLaSalle]
#3261227
10/01/24 12:15 PM
10/01/24 12:15 PM
Posts: 75 norcal
JLaSalle
norcal
A little backstory here...I bought all the rotating assembly parts new and gave them and the block to my machinist to bore/hone and have balanced.His longtime trusted balance shop is no longer doing that,so he went to a different place for balancing.Now there's 2 things about the balancing on the crank that have me asking questions.First was starting to use a bit wider than the counterweight in the 2nd photo...oops.And through my research it seems that a crank for a 451 with counterweights cut down to 7.25" shouldn't need a lot of drilling. My machinist is a decent drive from me and doesn't answer phone calls and the shop that balanced is even farther.Just wanted to get some more info here before I made the trip down and asked about the work.
[Re: AndyF]
#3261292
10/01/24 04:45 PM
10/01/24 04:45 PM
Posts: 75 norcal
JLaSalle
norcal
Very helpful info Andy,thank you!
[Re: AndyF]
#3261398
10/02/24 09:28 AM
10/02/24 09:28 AM
Posts: 8,926 fredericksburg,va
cudaman1969
Itch Nutz
Itch Nutz
fredericksburg,va
I don't think we've ever used a crank from Ohio Crank so I can't tell you if that is a bad job or a normal job. We typically use Molnar cranks and they only require a small amount of touchup to build a 451 or 470 type of engine. I think 440 Source cranks are rough balanced at 2400 or 2500 grams these days and most modern rotating assemblies balance around 2400 grams. If you have the part number for the crank you can call Ohio Crank and see what the rough balance numbers are on the crank. Then you should be able to see from the machine shop info what the bobweight of your assembly was. If the crank is built correctly it usually only takes a small amount of metal removal to balance. Here is the rotating assembly from the last 470 I built. It was a Molnar rotating assembly and I don't recall the balance job taking much time. That 2400 is good to know, I have two that will need balancing both have a number close to that, 4.15 and 4.5
