A727 repair in DFW area? #3260903
09/30/24 11:54 AM
09/30/24 11:54 AM
Dallas, TX
440Brian Offline OP
440Brian  Offline OP
Dallas, TX
I need someone to fix my transmission. I pulled it after I lost first and second gear after my last burnout. I found out the last guy that I took it to recently passed away. It’s a CRT built unit with about 400 passes total.
Does anyone have somebody in the DFW area?
I would like to get it done before Saturday so I don’t have to use my old mostly stock backup.
Thanks for any help.
Re: A727 repair in DFW area? [Re: 440Brian] #3260909
09/30/24 12:15 PM
09/30/24 12:15 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
John cope couldn't fix a bicycle chain , surprised it lasted that long .
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: A727 repair in DFW area? [Re: 440Brian] #3260915
09/30/24 01:15 PM
09/30/24 01:15 PM
WA
tman Offline
tman  Offline
WA
This guy looks like he knows what he is talking about, love his videos and he was in Amarillo but has moved to a new location. Phone number on the wall.
https://www.youtube.com/watch?v=0uofSlDLnmY
Re: A727 repair in DFW area? [Re: tman] #3260925
09/30/24 01:59 PM
09/30/24 01:59 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
You could try pro trans down in Waco. They certainly can get the job done
418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car
1.41 best 60 foot
6.54 @ 105.20
Re: A727 repair in DFW area? [Re: B3422W5] #3260933
09/30/24 02:50 PM
09/30/24 02:50 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
Right there.
Lucky for you to have him it TX.
Sucks we lost him from So Cal.
Fall Fling 28 October 19, 2024 at Woodley Park, Van Nuys CA
300+ Mopars, 125+ swap, midway, Friday Malibu cruise,
Re: A727 repair in DFW area? [Re: autoxcuda] #3260967
09/30/24 03:56 PM
09/30/24 03:56 PM
Georgia and Washington
JMCarter Offline
JMCarter  Offline
Pro Trans and A&A usually have huge backlogs…I’d post this on ClassRacer.com….or I can if you’re not a member.
Re: A727 repair in DFW area? [Re: B3422W5] #3260979
09/30/24 05:11 PM
09/30/24 05:11 PM
Dallas, TX
440Brian Offline OP
440Brian  Offline OP
Dallas, TX
Thanks for the replies.
I called Pro Trans down in Waco. It only took me about 90 minutes to get down there. I shouldn’t have worried about finding someone in the immediate area.
Re: A727 repair in DFW area? [Re: 440Brian] #3261075
09/30/24 08:58 PM
09/30/24 08:58 PM
Kansas
Thelma133 Offline
Thelma133  Offline
Kansas
Pro trans, great.
Re: A727 repair in DFW area? [Re: 440Brian] #3261154
10/01/24 08:12 AM
10/01/24 08:12 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
don't live in the DFW area. I have built transmissions for 50 years, and taught drivetrains at a technical college before I retired. ANY reputable transmission shop should be able to fix your trans. a 727 is one of the easiest transmissions to rebuild. Just look for a shop that has an old guy still working.
Re: A727 repair in DFW area? [Re: jwb123] #3262062
10/04/24 10:40 PM
10/04/24 10:40 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
You will not regret going with Pro Trans, great folks!
