Titanium bolts
#3260841
09/30/24 07:27 AM
09/30/24 07:27 AM
Posts: 6,187 Melbourne , Australia
LA360
Has anyone used titanium bolts in their race car? Which areas did you use them in? Anyone used them in your race cars front or rear suspension ?
Alan Jones
Re: Titanium bolts
[Re: LA360]
#3260842
09/30/24 07:33 AM
09/30/24 07:33 AM
Posts: 23,823 Here
jcc
No soup for you!!!
No soup for you!!!
Here
I use them selectively. For example, I use composite leaf springs, and the extruded alum eye fittings on each end of the leaf are attached with 4 1/4" Ti hex bolts. I also have Ti wheel studs, but they make me anxious as TI doesn't have the robustness of typical Grade 8 stuff,
I forbid my content here from being learned and used by artificial intelligence systems.
Re: Titanium bolts
[Re: jcc]
#3260866
09/30/24 10:06 AM
09/30/24 10:06 AM
Posts: 19,635 Las Vegas
Al_Alguire
Las Vegas
Yes we do. In many areas for sure. Anyplace we can actually. Wheel studs, wheelie bar bolts, wheel center and beadlock bolts, anything that holds parts of the car on, fender doors etc. Pretty much anywhere we can
Re: Titanium bolts
[Re: Al_Alguire]
#3260937
09/30/24 03:03 PM
09/30/24 03:03 PM
Posts: 4,978 Florida
BDW
Yes we do. In many areas for sure. Anyplace we can actually. Wheel studs, wheelie bar bolts, wheel center and beadlock bolts, anything that holds parts of the car on, fender doors etc. Pretty much anywhere we can What’s the weight savings? Is there a rule of thumb, 20%?
Re: Titanium bolts
[Re: BDW]
#3260974
09/30/24 04:40 PM
09/30/24 04:40 PM
Posts: 7,573 Minnesota
Hemi_Joel
Minnesota
I have not used titanium, but in areas that are low stress, I have used aluminum bolts. They are pretty cheap and readily available. And save a lot of weight over steel.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Titanium bolts
[Re: Hemi_Joel]
#3261000
09/30/24 05:55 PM
09/30/24 05:55 PM
Posts: 12,719 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Racebolt, manufacturing bolts out of chrome moly tubing. I always thought that was a great compromise between weight and strength. Cheaper than Ti I suppose. $10 - 20 per bolt. Most everything we do has a minimum weight. While we're OCD about weight, we look for the most cost effective ways to reduce it first. Using smaller fasteners to hold stuff together is another option. Everything that goes into a car is looked at with a focus on "is there a lighter option".
Re: Titanium bolts
[Re: Hemi_Joel]
#3261005
09/30/24 06:21 PM
09/30/24 06:21 PM
LA360
I have not used titanium, but in areas that are low stress, I have used aluminum bolts. They are pretty cheap and readily available. And save a lot of weight over steel. I was thinking aluminium bolts for various parts of the car. I imagine using anti-sieze would be rather important?!? Cab, you can buy them from here: https://wmtitanium.com.au/
Alan Jones
Re: Titanium bolts
[Re: BDW]
#3261012
09/30/24 06:30 PM
09/30/24 06:30 PM
LA360
Yes we do. In many areas for sure. Anyplace we can actually. Wheel studs, wheelie bar bolts, wheel center and beadlock bolts, anything that holds parts of the car on, fender doors etc. Pretty much anywhere we can What’s the weight savings? Is there a rule of thumb, 20%? An example 1/2" bolt by 2" long 316 S/S = 65 grams Ti6Al4v = 36 grams 2024 Aluminium = 22.5 grams
Alan Jones
Re: Titanium bolts
[Re: LA360]
#3261013
09/30/24 06:31 PM
09/30/24 06:31 PM
Posts: 2,506 Sydney,Australia
tex013
Sydney,Australia
I wonder how the titanium wheel nuts would hold up to street/strip use ? Definately would prefer the inbuilt face / washer than what i currently use on aluminium wheels which stuff the washers . https://wmtitanium.com.au/products/wheel-nut-12-pt-1-2-unfx36-1-42Tex
New best ET 10.259@129.65 . New best MPH 130.94 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: Titanium bolts
[Re: tex013]
#3261025
09/30/24 06:53 PM
09/30/24 06:53 PM
Posts: 23,823 Here
jcc
No soup for you!!!
No soup for you!!!
Here
I think a Ti lug nut would be a proper Ti application, as there can be extra threads to improve strength, and they are not repetitively loaded like a wheel stud might be flexed.
Re: Titanium bolts
[Re: LA360]
#3261112
09/30/24 11:39 PM
09/30/24 11:39 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Yes we do. In many areas for sure. Anyplace we can actually. Wheel studs, wheelie bar bolts, wheel center and beadlock bolts, anything that holds parts of the car on, fender doors etc. Pretty much anywhere we can What’s the weight savings? Is there a rule of thumb, 20%? An example 1/2" bolt by 2" long 316 S/S = 65 grams Ti6Al4v = 36 grams 2024 Aluminium = 22.5 grams Quick calculation gets me .500 x .120 wall x 2" 4130 = 36 grams. Plus a few gram for the nut. Pretty close to Ti.
Re: Titanium bolts
[Re: Cab_Burge]
#3261121
10/01/24 12:35 AM
10/01/24 12:35 AM
Posts: 1,927 South Bend
John Brown
South Bend
Quick approximation;
Steel = 1.00
Titanium = .500
Aluminum = .333
Not 100% accurate, but close enough.
Re: Titanium bolts
[Re: John Brown]
#3261132
10/01/24 05:52 AM
10/01/24 05:52 AM
Posts: 23,823 Here
jcc
No soup for you!!!
No soup for you!!!
Here
Steel = 1.00
Titanium = .500
Aluminum = .333
Not 100% accurate, but close enough. And fatigue comparison life would be steel 1, Ti .4, alum .1, as a wild guess. Edit: my "wild guess" above on Ti fatigue life is a bit wild, I'll just go on record to say it's less than steel and more than Alum. Might also consider for all the weight savings Ti offers, how rare it is found in Connecting rod bolt applications
Re: Titanium bolts
[Re: jcc]
#3261188
10/01/24 10:20 AM
10/01/24 10:20 AM
Al_Alguire
Las Vegas
I buy most of mine from TI-64. Have run titanium studs for YEARS on front and rear on a few cars. Never had an issue. That being said I am sure thye have a shelf life and will get cycled out at some point but they are checked visually frequently. AS for lugnuts aluminum is lighter...So that's what we use.
Link to TI64
https://www.ti64.com/#:~:text=Retrofit%20your%20race%20car,%20watercraft%20or%20sports%20gear%20with%20our
Re: Titanium bolts
[Re: John Brown]
#3261217
10/01/24 11:45 AM
10/01/24 11:45 AM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Steel = 1.00
Titanium = .500
Aluminum = .333
Not 100% accurate, but close enough. Keep in mind the 4130 bolts are hollow. Likely less than half the weight of a solid piece.
