Needle/seat fuel bowl repair #3260250
09/26/24 03:21 PM
09/26/24 03:21 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Is there anything available to repair these out on the market?
Re: Needle/seat fuel bowl repair [Re: racerx] #3260259
09/26/24 03:50 PM
09/26/24 03:50 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
They used to make needle/seats with oversize threads for stripped bowls. Probably still do. Back in the day napa had them.
Re: Needle/seat fuel bowl repair [Re: B1MAXX] #3260281
09/26/24 05:07 PM
09/26/24 05:07 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I have been meaning to make a setup to repair those. I have the correct tap. Believe that the last time I looked at one I planned to thread a brass bushing in.
One of the members here had his six pack center carb bowl repaired. They pressed the bushing in. Did not last at all. Bushing fell out.
Re: Needle/seat fuel bowl repair [Re: markz528] #3260291
09/26/24 06:05 PM
09/26/24 06:05 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Re: Needle/seat fuel bowl repair [Re: B1MAXX] #3260294
09/26/24 06:13 PM
09/26/24 06:13 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Re: Needle/seat fuel bowl repair [Re: B1MAXX] #3260332
09/26/24 10:44 PM
09/26/24 10:44 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
BLP or Braswell sells thread repair kits for the squirters and the bowls, or used to ten years ago when my Holley HP stripped out.
Google search yielded this:
https://www.ebay.com/itm/384279475063
While it is overly expensive you get an idea of what you need to do. The threads are 3/8-32 aka ultrafine.
Re: Needle/seat fuel bowl repair [Re: Jeremiah] #3260348
09/27/24 05:35 AM
09/27/24 05:35 AM
Charleston, SC
SCDaytona Offline
SCDaytona  Offline
Charleston, SC
BLP has a Bare bowl for $28
Re: Needle/seat fuel bowl repair [Re: B1MAXX] #3260350
09/27/24 06:22 AM
09/27/24 06:22 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Originally Posted by B1MAXX
Thanks ,B1MAXX up
Re: Needle/seat fuel bowl repair [Re: Jeremiah] #3260351
09/27/24 06:24 AM
09/27/24 06:24 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
eek
Re: Needle/seat fuel bowl repair [Re: SCDaytona] #3260352
09/27/24 06:25 AM
09/27/24 06:25 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thank you coffee
Re: Needle/seat fuel bowl repair [Re: Jeremiah] #3260368
09/27/24 08:15 AM
09/27/24 08:15 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
That is how I plan to repair them but I plan to thread mill the repair thread not use a tap. Only use a tap for the seat threads.
Re: Needle/seat fuel bowl repair [Re: racerx] #3260399
09/27/24 10:51 AM
09/27/24 10:51 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Many years ago, before the current repair parts were available, I was repairing the bowl threads by boring out the damaged threads and installing a fabricated thread insert. The insert was held in place by fuel-proof epoxy.
Re: Needle/seat fuel bowl repair [Re: SCDaytona] #3260476
09/27/24 06:11 PM
09/27/24 06:11 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Exactly iagree Unless its a rare one off carb why even mess with it when you can get a better bowl with a sight glass and fresh threads. shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: Needle/seat fuel bowl repair [Re: fourgearsavoy] #3260613
09/28/24 01:49 PM
09/28/24 01:49 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
I find good used bowls on E-bay for $25.00
Re: Needle/seat fuel bowl repair [Re: 469runner] #3260652
09/28/24 05:27 PM
09/28/24 05:27 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Honestly, the last thing I want is fuel coming out of something it's not supposed to.
Buy a damn bowl - they're easy to find, and a lot cheaper than a fire.
Re: Needle/seat fuel bowl repair [Re: fourgearsavoy] #3260789
09/29/24 04:30 PM
09/29/24 04:30 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Exactly iagree Unless its a rare one off carb why even mess with it when you can get a better bowl with a sight glass and fresh threads. :shruggy
True, but the original bowls for factory carbs like the one I pictured might not be as easy to get. Repair becomes the only option
Re: Needle/seat fuel bowl repair [Re: topside] #3260833
09/30/24 06:33 AM
09/30/24 06:33 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Getting ready to put in an order to BLP. Wish me luck need to order a few other items .They seem to screw up every time I place an order with them, and it end up costing me more on return shipping.
Re: Needle/seat fuel bowl repair [Re: racerx] #3260837
09/30/24 06:54 AM
09/30/24 06:54 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Looking to replace both bowls with a set of these;
https://blp.com/cart/index.php?main_page=product_info&cPath=65_95_238&products_id=1716
curios if the sight glass will hold up to E-85 fuel work anyone here run this bowl with E-85?
Re: Needle/seat fuel bowl repair [Re: racerx] #3262078
10/05/24 05:01 AM
10/05/24 05:01 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
I decided to go a different route on these fuel bowl, I'm looking into purchasing a set of the dual needle and seat bowls.
My question is anyone here powder coated the outer shell of the fuel bowls I'm using E-85 fuel and wondering how the E-85 affects the coating work?
